Beta tester takes car to dyno..... - FirebirdV6.com/CamaroV6.com Message Board
  • #46
    could you not be hiting the speed limiter(the computer starts to pull fuel) on the dyno when you do
    IE on a normal car it would pull fuel at 118mph
    your car it would start at that 90mph(actull speed) or so because your compter thinks you are going 118 because your tires are turning faster then what the computer is programed for because of your gear swap
    IE hawgs went from 3.08's(or 3.23's i cant remeber) to 3.42s, before he got his computer reprogramed we were side by side on the freeway I called him on his cell and asked what his speed was he said 70mph when my correct speedometer was 60mph
    your diffrence is even worse
    i bet the computer is pulling fuel and thats your shudder because you are toping the car out(speed wise) with the stock computer
    does it shudder in 1st or 2nd gear
    also im sure your car is shifting at like 5K rpms instead of the 6K which you can pull too
    [ March 03, 2004, 01:05 AM: Message edited by: Drone51 ]
    • #47
      Thats exactly it....My car thinks its at 118, when its really in the upper 90's
      I am roughly 15-17 MPH off on the speedo, and obviously the difference gets larger as your speed goes up. So at 118, the difference is probably above 20 MPH.
      The only problem with the thoery that it is pulling the fuel because of the limiter, is that this shuddering can happen in 2nd (not to often) if I punch it hard enough....It happens in third when I punch it, and in fourth it happens in the upper RPM's. It will NOT happen in 1st gear.
      I am hoping new wires will fix this problem in 2nd and 3rd.
      Keep in mind, fuel pressure has been perfect this entire time, and continues to look good even when the car shudders up top.
      Hopefully a combination of new wires, raised speed limiter, and programming for the 3.73 will fix everything. [img]graemlins/stickpoke.gif[/img]
      <b><a href=\"http://members.cardomain.com/redaudiomobile\" target=\"_blank\">1998 Red A4 W68 Firebird</a> <br />10 PSI <a href=\"http://www.procharger.com/superchargers.shtml\" target=\"_blank\">ATI Procharger</a> <a href=\"http://www.imagestation.com/picture/sraid81/pb4b6eeb42f57d06389e3ac12068e7a67/faff97eb.jpg\" target=\"_blank\">Intercooled</a> </b> <br /><b>~~</b>Borla catback, <a href=\"http://www.imagestation.com/picture/sraid91/pf2d3103bcf8fef15756e8ec41c695d6c/fa6c671d.jpg\" target=\"_blank\">3” Catco Cat</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p8e41ca8b59b95024690456cd102f7c65/fa6c672a.jpg\" target=\"_blank\">Pacesetter Ceramic Coated Headers</a>, 3.73 gears, Zexel-Torsen<br /><b>~~</b> <a href=\"http://www.imagestation.com/picture/sraid91/p5f73f1370269f5c5334b6d8cbbeec4d1/fa6c6712.jpg\" target=\"_blank\">K&N Air Filter</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p9da8e4ea1855acbbfb5067bc9762b9b6/fa6e6fe4.jpg\" target=\"_blank\">TSP Clear Lid</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p4f9c7720261bdd59f9e55275f022ef8d/fa6c6706.jpg\" target=\"_blank\">SLP CAI</a>, 160* thermostat, <a href=\"http://www.imagestation.com/picture/sraid81/pec71087de994f110a77b62a06ab5b77d/faff953c.jpg\" target=\"_blank\">Autometer C2 Gauges</a><br /><b>~~</b> <a href=\"http://www.imagestation.com/picture/sraid88/p70f4e24cb84ebce6e87577a1086b47a0/fa901042.jpg\" target=\"_blank\">Katzkin Black/Red Leather Seats</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p768a90d0c13e9740c0d353ac1b322e6a/fa6c6717.jpg\" target=\"_blank\">Bilstein HD Shocks</a>
      • #48
        hey good luck with getting the bugs worked out..
        hopefully you can get the speed limiter removed.. full dyno pulls are crutial for supercharged cars.. since its rpm related.
        hope everything turns out well.
        sorry to hear about your mom.. run the guy over with your car
        96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
        • #49
          nah.. blood's a b*tch to get off a bumper
          ~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
          • #50
            His cars red though....so maybe not as much a problem.
            \"Since I started working, every single day has been worse than the day before, so that every day you see me is the worst day of my life\"
            • #51
              Good Luck with it.... I hope it all gets ironed out.. :D
              • #52
                I might be repeating what someone already said (thread is too long now) but Green is right. 3.08 to 3.73 is a big jump in gears and you would hit your limiter alot sooner than those who went from 3.43 to 3.73. When Mach was doing your computer, did they know about your gear swap?
                I don't know if gear is the culprit. There may be other bugs that's plaguing you. This seems to be typical or any FI.
                Good Luck and hopefully everything works out. You got an awesome setup. Love your pictures man.
                • #53
                  tru dat [img]smile.gif[/img]
                  • Manimal
                    Coil springs
                    by Manimal
                    4 days ago
                  • Manimal
                    Newby here
                    by Manimal
