go with your stock air box. that one you are getting has flex tubing which you can most likely use.
fitting the whisper lid might be a problem, I think the whisper might have a longer discharge neck that could get too close the the TB and the blower discharge tubing. try it..see how it looks. hopefully you still have your stock air lid. if the whisper will not fit then shave the inside of stock airlid and you can use pvc pipe as short coupler to the flex hose. check out my site. (v8 whisper lid is the best...it has discharge port in center of lid not off to the drivers side like the v6.)
you will also need to plug the hole in the whisper lid because you will be moving the IAT sensor over to the blower discharge tube.
01 Firebird A4 3.42
Powerdyne @ 6 PSI
and other mods
Originally posted by grayman: go with your stock air box. that one you are getting has flex tubing which you can most likely use.
Hmm ok, i dont think taking a hacksaw to the whisper lid willbe a problem to shorten it, and that also might solve the IAT problem..
1999 Black V6 Camaro<br />Website: <a href=\"http://midnight-maro.freestarthost.com\" target=\"_blank\">http://midnight-maro.freestarthost.com</a> <br /><br />CAI,Lid,K&N,SLP LM, Powerdyne, Shift Kit, 160* thermo, and gauge pillar w/gauges.. Sittin in the garage: RKSport Headers, Carsound Cat, LSD, Fuel Pump, GTP Injectors, 3.73\'s
