How long is this going to take? I will be in town for about a day, is this enough? I am probably average when it comes to mechanics... i have only installed my intake stuff. I was trying to have a whole weekend but its not working out so can a friend and i do it in a day?
Powerdyne Install
Powerdyne Install
1999 Black V6 Camaro<br />Website: <a href=\"http://midnight-maro.freestarthost.com\" target=\"_blank\">http://midnight-maro.freestarthost.com</a> <br /><br />CAI,Lid,K&N,SLP LM, Powerdyne, Shift Kit, 160* thermo, and gauge pillar w/gauges.. Sittin in the garage: RKSport Headers, Carsound Cat, LSD, Fuel Pump, GTP Injectors, 3.73\'sTags: None
I installed my Powerdyne in about 4 hours. Could do it alot faster now. Headers were a day and a half. Gauges about two hours to do it right. 3 in a A pillar pod.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
ok well im not doing headere yet, i know i need a weekend for that, but i think it seems that i can probably get er done in a day..1999 Black V6 Camaro<br />Website: <a href=\"http://midnight-maro.freestarthost.com\" target=\"_blank\">http://midnight-maro.freestarthost.com</a> <br /><br />CAI,Lid,K&N,SLP LM, Powerdyne, Shift Kit, 160* thermo, and gauge pillar w/gauges.. Sittin in the garage: RKSport Headers, Carsound Cat, LSD, Fuel Pump, GTP Injectors, 3.73\'s
Do you have to have headers with a powerdyne?<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
if you do it in 3 hours then you are doing it wrong.
guages, fuel lines for fuel pressure sender/fmu, routing vac lines, tb pcv plug, oil presure sender elbow, john d wrap (filing down oil filter elbow) and more.
all of the above can be done ahead of time and it will not mess up your car. If the things i mentioned above are new to you...then....http://home.comcast.net/~grayman99/guide.htm
don't put a time limit on converting your naturaly aspirated engine to forced induction. there is a lot more involved to this than just mounting the powerdyne head unit.
oh yea...replacing your spark plugs will take some time as well with your log manifolds. do all this stuff ahead of time and THEN it will take 3 hours to put the head unit in....pulley puller...figuring out what spacers go where...getting the blower unit down in the engine bay fighting with the ac lines...torqueing it down and then tightning the belt.
if you don't do all the related things ahead of time then you willmost likely be making several runs to part store more misc tings like pulley puller, teflon thread tape, vac t's, tb gasket...etc.
thanks grayman, yah i have read through pretty much everthing on your site, out of it what all can i do that wont do any damage becuase htat would be a smart thing to get ahead.1999 Black V6 Camaro<br />Website: <a href=\"http://midnight-maro.freestarthost.com\" target=\"_blank\">http://midnight-maro.freestarthost.com</a> <br /><br />CAI,Lid,K&N,SLP LM, Powerdyne, Shift Kit, 160* thermo, and gauge pillar w/gauges.. Sittin in the garage: RKSport Headers, Carsound Cat, LSD, Fuel Pump, GTP Injectors, 3.73\'s
you can do everything ahead of time. tb pcv plug with valve cover breater, john d wrap prep, vac lines for boost gauage and fmu, you can even install fmu now, oil pressure sender elbow, you can even do spark plugs ahead of time. the more you do now the less stress when you actually put the blower on. you will have had time to see that your new vac lines are not leaking, etc.
nothing goofy should be going on with theengine when you install the blower...make sure it is running fine before tackling this project. when the blower is on the car the only difference you will notice is that the main serpentine belt (might) cause squeeking from the AC compressor when the car is idling and the AC is on. other than that you will not notice anything odd about your new forced induction car...other than the fact that it has A LOT MORE POWER when you punch it...
Originally posted by Yaba3800:
is it noisy because i want a sleeper
If you are refering to noise from the supercharger itself...no, it basicaly does not make noise. If you hear it at all it is only because YOU know what to listen for. Other people in and outside of the car will not hear it. the powerdyne is virtually no noise.
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
