Boost guage question. - FirebirdV6.com/CamaroV6.com Message Board
  • Boost guage question.
    Howdy.
    I have a question about mechanical boost guages. Can you 'zero' them if they're off? Mine reads 4 on the vacuum side not hooked up. Hook it up and it functions right in terms of moving for vacuum to about 22 and then drops a bit as the idle drops... and in boost it does climb into the positive...
    When the boost says 5psi, is it really 9? Is it just a faulty guage or can it be 'zero'd? It's a Sunpro mechanical.
    thanks
    1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
    That sounds about normal. Usually the car is under vacuum most of the time, even at idle. 5psi is actually 5.
    A setting of '0' is more true for Root and twin screw blower. For us turbo and centrifugal we are under vacuum.
      wow, no idea...but mine is at zero when car is off and when the gauge was new and in the box.
      01 Firebird A4 3.42
      Powerdyne @ 6 PSI
      and other mods
        I'm wondering if i could test the guage? Any thoughts on a sure source of say 10psi that i could hook it up to? Don't say my tire for 33psi :D
          Opps, mis-understood that one. Yes, it's suppose to rest on zero when the car is off.
            So you think that reading 5psi is actually 9 then?
            I want to test it... haven't found a method yet.
