welders: need advice... - FirebirdV6.com/CamaroV6.com Message Board
  • welders: need advice...
    ive got a pretty plain wire feed craftsman welder. we picked it up on sale a while ago for about 200 bucks at sears.
    i know just about nothing about welders besides the actual process/technqie of welding. What sort of jobs would i be able to tackle with a welder like this.
    will it be able to weld portions of my pacesetters/ypipe? I'm assuming these are not stainless...
    as far as cutting the pipes, it will be done with just a sawzall and an angle grinder.
    Visit My F-Body Page
    That welder is only made for use on thin material like exhaust piping. So it will work great for that. You probably will not be able to get a good weld on anything over a 3/16" thick.
    I am new to welding also. I just recieved my welder this week and spend the last two nights messing around with it. I got a 110v hobart. I got it basicly for exhaust work. I am making turbo headers for my truck. Although I am just going to be tac welding them and then take them to my uncle to get tig welded.
    http://www.gmv6.org/images/welder/hobart01M.jpg
    I am assuming you are running flux-core wire which required no gas. That should work fine, but if you plan on using the welder alot, I would get an argon/co2 bottle with solid wire. It comes out much cleaner.
    92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
      sounds like ill probably see how much i can get done with this one. if it works, im not really too concerned with how the welds look. i can always clean the welds up afterwards anyway.
      • Manimal
        Coil springs
        by Manimal
      • Manimal
        Newby here
        by Manimal
