Alright I am doing my pcv bypass today and I ordered the suggested plug and it is too big it is 3/8 but it says 18-8 on the back do I have drill a bigger hole for it? let me know quick
pcv plug
don;t drill a bigger hole.
i think you said you have a 3/8 tap with 16 threads per inch. that is the plug you want. seriously, hex plugs like this are everywhere. they are used as 'set' screws and carbeurator plugs and for blocking un used holes in intake manifolds and as plugs for un used mounting holes in engine blocks, etc. If you live in the deep boonies with no stores around then...i can see you having a problem. If you live anywhere near any real population density then you should be able to find them. I got mine at my nearby family owned small ace hardware store. autozones should have them as well. sometimes auto stores have there specialty fittings behind the counter.
try printing the pic from my websit and take that around with you.
I have a 1/4 threaded pipe plug that almost fits but doesnt really go....I have asked around and no one seems to have it except advance auto parts...If I drill a bigger hole then the tab would be too small...2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
is that the actually name...i am going to auto zone tommorrow and ask for a 3/8x16 set screw or what is the real name of it so I can go to lowes or home depot and pick one up2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
