How does return drain work for the coolant lines? I know your turbo is mounted pretty downlow in the engine bay as well. Mine are mounted on both sides of the oil pan.
Please advise me [img]smile.gif[/img]
Sam
[ March 03, 2003: Message edited by: xjarayax ]</p>
AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
I put the turbo on w/o a oil cooler 1st. It was last march and in 80-90 degree temps my oil temp gage would climb to 240 if I was sitting still. I then hooked up the water coolant lines to the turbo but that didn't help much. Then I added a perma-cool oil cooler from summit w/ a fan on it for sitting in traffic and the temps during the summer don't get above 210 sitting, and while driving they stay below 180.
