oil viscosity and turbo - FirebirdV6.com/CamaroV6.com Message Board
  • oil viscosity and turbo
    I searched, didn't find anything :(
    Do any of you boost guys run more than 10w30 synth? Just wondering if there's a recommendation. I'm having leaks and im fixing them as i find them but it would be nice to use a thicker oil if i could [img]smile.gif[/img]
    1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
    15W 50 is what i run mobile 1
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      so you'd recommend that over 10w30?
        no problems here
          I run 10w30 offbrand sythentic brend and its fine.
          1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
            15W 50 made a HUGE difference in the way my motor ran. Everything seemed sluggish. I could actually hear things in the motor that I hadn't heard before. Its WAY overkill if you ask me. 10W-30 should be perfect.
            -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
              I'm just wanting to try a thicker oil to cut down on the leaking until i can get my rear main looked at again. :(
