Hmmm, you have had your share of challenges and gremlins with your project for sure! I found some basic fuel system troubleshooting info at this link:
http://www.mityvac.com/fuelpressure.html
It might give you a little more insight. If you don't have a clogged fuel filter, kinked fuel line, bad fuel regulator or insufficent voltage to the pump (high resistance relay contact). I suspect 'infant mortality' on the new pump. If that's the case and the pump is brand new, complain loud and long to the manufacturer, they done u wrong.
Good Luck,
HH
Good Luck,
HH
