Hi everyone, I have a 1996 3800series camaro. I've been told by man of others that I can take a super charger from a Grand Prix GTP or SSEI and it will pretty much bolt into my camaro. I was wondering if anyone here has ever heard of that, or if its possible.
And your answer is NO. Unless you have the time and money to make it REALLY work.
<i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
So it is possible then??? Im seeing no unless you have time and money. The GTP superchargers are cheap !. All i was wondering is if it will work with mine.
Originally posted by Gidds: So it is possible then??? Im seeing no unless you have time and money. The GTP superchargers are cheap !. All i was wondering is if it will work with mine.
see it puts the TB in the back of the motor bay, so you have to bring the intake thought the Firewall, yeah you can't
and the SC will not fit under the hood there is no clearance, and you only going to get like 60 HP anyway......
No, the charger wont work. I recently looked into getting one becuase you can buy them all day long for REAL cheap. First off the GTP is front wheel drive. The engine sits sideways compared to ours. In other words, the charger will not fit unless you move your throttle body and intake. You'd have to find a place for the nose and pulley too. I was also told that the manifold sits higher, but not too sure about that. Anyways, the GTP charger would only add about 60hp and isn't worth the time and money it would take to put that in your ride. Save up and get a ForecFedFab kit. That's what I'm doin'.
BUT...Like said above its a pain in the a55. You will spend WAY more money on new parts, labor, and Jack Daniels then you would just buying a SC kit from RKsports or even a use LS1 and tranny. All of that for 60hp is just crazy.
BTW moving to forced induction forum ;)
White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
^^^ yeah ...i called (someone..i forget who) about doing this to my car before i went with the powerdyne...they said the same thing..would cost way more to make it work than it would to just buy a kit
I will help you out so u dont have to search. [img]smile.gif[/img]
you would need:
gtp heads
gtp intake manifolds(upper and lower)
gtp supercharger/throttle body
gtp harmonic balancer
gtp fuel rail and injectors
diffent kind of hood for clearance
I dont know what u would need to do about the firewall. There was talk about using a Holden M90(RWD version) from australia which would probably clear the firewall but they are not easy to find.
