I'm buying a junk motor here soon, to rip apart and rebuild from scratch. How much boost do you think I would be able to run through a motor w/ forged rods and pistons?
how much boost??
how much boost??
_davjos81- 02 v6<br /><a href=\"http://www.cardomain.com/id/davjos81\" target=\"_blank\">www.cardomain.com/id/davjos81 </a><br /><a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\"> <a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\">http://community.webshots.com/user/davjos81</a> </a> <br /><br />-over $8,000 invested! Too many mods to list, just check out my site!!Tags: None
Whats you compression ratio? What octane are you going to be running? Intercooler?Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
im talking to tiago, im going to run a big front mount intercooler, 8.0:1 compression pistons, forged rods, replace all the bearings, and have the motor bored .10 over. Ill run 93 octane, daily, maybe something higher to race._davjos81- 02 v6<br /><a href=\"http://www.cardomain.com/id/davjos81\" target=\"_blank\">www.cardomain.com/id/davjos81 </a><br /><a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\"> <a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\">http://community.webshots.com/user/davjos81</a> </a> <br /><br />-over $8,000 invested! Too many mods to list, just check out my site!!
All just depends on how much money you spend on it, really. You could build a stout little motor to run 30psi if you wanted. For pump gas, i'm thinking the most you'd want is around the 15-18psi range. you could probably go higher with 8.0 c/r, but that's generally the good rule of thumb.1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
One way to look at it is figure out how much power it will most likely make N/A say you figure it will make 250hp n/a.
Then when you dubble the absolute pressure (run 15psi of boost) you will dubble the power out put.
The turbo size is just as important as the engine build in this case.
How much work were you going to have done?
heads P&P, turbo cam, (custom if you are going to run much over 20psi) and stuff like that will cause your boost pressure to be lower but hp out put to be higher.
If you get P&P heads and intake, valve train, custom cam, forged pistons and rods, the right size turbo, big intercooler, the fuel and fuel system. You could run 20psi but I think you would have to use race gas.
8:1 would be good for 20psi I think.
The 3800II has Al heads, yes 8:1 will be good.
With that much boost you will have to think a little bit harder about cylinder sealing like what cylinder head gasket you will use and if U will copper or SS O-ringing the block.
I have herd that an engine running that much boost can have combustion chanber pressures high as 3,000psi or more. Not much room for error.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
i would suggest running a higher compression of about 8.5:1 and a lower boost of about 15psi. at that level you will run about 400hp with a propper setup with all forged internals. now if you want to go all out a forged 4.1 stroker kit will be available soon and with that you would want to get the 8:1cr pistons because the stroker adds more compression (with 8:1 it would change it to somewhere between 8.5 and 8.7:1) this would still allow for 15 psi if you upgrade your vavetrain and do some extensive headwork. again though at this level you will probably want to get a custom cam and you will have to do some work with your seals. and as oilpan said (and i cant stress this enough) your turbo choice is as important as you engine build.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
OILPAN: the 3.8 DOES NOT HAVE AL heads they are cast IRON
8:1 will be fine that's what intense drag car runs.
you will want to order tiagos kit and upgrade to the t-66 or t-72. that the mistak i made and only time will tell if the turbo will push my 7100 RPM limiterwww.turbov6camaro.com
1997 3800 Series II Camaro
this should help you alot http://www.smokemup.com/auto_math/index.phpwww.turbov6camaro.com
if you run 8.5:1 c/r at 20 psi
Result:
20.06 : 1 Effective Compr. Ratio :eek:www.turbov6camaro.com
oh yeah dont forget you cam is a big factor in C/R toowww.turbov6camaro.com
First you are going to have to decide what you are going to do, race only or daily driver. You can build the engine for either. The Indy 500 speed record was done with a 3.8 stock block and they ran 3 bars (45 psi).
20-psi1989 TTA #609 - 12.42 @111.35 - stock<br />1991 Mustang GT - 12.52 @109.3 - mostly stock<br />2001 Yukon XL - tow vehicle - 16>49 @81.4
20-psiwww.turbov6camaro.com
