Over oiling the turbo - FirebirdV6.com/CamaroV6.com Message Board
  • Over oiling the turbo
    For my turbo setup, i was planning on using size -6AN lines and fittings to the turbo. After talking w/ my roomate about it, he said that i could damage the seals on the turbo. He suggested a smaller line like -3 or -4 AN. The only reason i chose the 6 was for convenience...swivel fittings were very hard to find in the 3 and 4 size. all i found in those sizes were the 90* square bent brass brake line fittings, where i wanted a more aesthetically pleasing red and blue annodized swivel fitting.
    will the larger size damage the turbo?
    if so, could i just install a size -3AN oil inlet on the turbo and adapt down to it, using it as a restrictor?
    will the oil pump be able to handle approx. 7 total feet of size -6AN oil line?
    ~3 ft. to & from remote filter
    ~1.5 ft. to turbo
    ~2.5 ft. to & from oil cooler...coming off the remote filter.
    thanks for any help offered, but please don't post unless you know what you're talking about.
    1998 Chevrolet Camaro L36 M5<br />1982 Toyota Celica Supra 7MGTE project car - FOR SALE<br /><br />\"I find the most sensual part of the woman is the boobies.\" - Zap Brannigan
    summit ahs you covered
    http://store.summitracing.com/defaul...Search&Ntt=ear
    look at "Earl's Performance Plumbing" eveythign thig you need
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      thanks...but...
      the smallest size of earls swivel, aluminum red/blue hose end is -6.
      i already have the hoses in -6, i need to know if it will damage the turbo.
        it wont damage the turbo....
        you could run a restrictive orifice inline if you wish to reduce the pressure to the turbo.
        I think you will be fine though.
          I persoanlly run a restrictor piece to make sure I'm not over oiling it.
          1996 Camaro, Built Motor(L/C,Cam, Ported), T66 FFF Kit, N20, 36 lb. Inject., FMU, 255 Walbro, 00+ Manifolds, SFC, LCA, Tubular K, Adj. PHR, 17x9.5,x11 Chrome ZR1, Front 35MM/Rear 21 MM Swaybars
            I used a nitrous jet.
            Past Ride
            1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
            (If you dont know me, you haven't had a V6 long enough)
            Current Ride
            2006 Mitsubishi Evolution GSR
            www.myspace.com/shane1015
              thanks for the help guys.
                5 days ago
