Does anyone have a clue on how much HP a stock 3.4L Crankshaft can take??? I'm in the middile of my Turbo/Rebuild and the crank is becoming the weakest link. How do I go about getting a better one if the stock one can handle it???
Crank Strength??
Crank Strength??
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
Originally posted by White95:
Does anyone have a clue on how much HP a stock 3.4L Crankshaft can take??? I'm in the middile of my Turbo/Rebuild and the crank is becoming the weakest link. How do I go about getting a better one if the stock one can handle it???www.turbov6camaro.com
1997 3800 Series II Camaro
I might be a little past that number with my set up and I don't want the most important piece to snap in half...Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
I might be a little past that number with my set up and I don't want the most important piece to snap in half...www.turbov6camaro.com
i believe the # was around 600 crank hp/torque before it will snap.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
I'll ask the my machine shop when I'm ready to drop it off. Thanks for all the help guys!Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Would it matter that I'm replacing the main bolts with studs????Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Studs yeald a higher maximum plastic deformation strength factor when compaired to bolts.
That means that the metal that the studs are made of can be equaly as strong as in the bolt, but by design the studs will hold a higher load before they bend or stretch.
The fastener is strong enough, the anchor isn't.
The crank will tear apart the block, most likely by deforming the caps then deforming the mains on the block, one with the torque and two by pulling in the metal where the studs anchor deforming the block.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
I was going to get a 3.4L crank and get it cryo treated.
Along with some rods.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
So what your saying is I should look into getting some new main caps??? And cryo teating the crank and block wouldn't be a bad idea???Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Treating the block would be extreamy expensive.
I don't know where you could get other than stock main caps.
The used stock main caps should be fine because they only had 160hp beating on them.
If cash is tight treat the main caps and rods, because those will most likey be stock parts and the first to fail.
And throw the new rings in as well while your at it.
Cryo treating costs around $10 per Kg or a little less than $40 for 20lb. That sounds cheap and I will recheck the numbers.
Cryo treating pistons has been proven to fight detonation like all most nothing else.
Forged after market pistons would be second after rods and caps for me.
Next time the guys at the cryo plant have to dump a tank I'm going to see if I can get a bunch of liquid nitrogen from them and experment with it on metals. Small things like knives/blades, cutting bits, punches and chisels.
When you have limited choices like this you have to change the orignal parts propteries.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
Well I'm getting Forged Pistons and Rods, and better wirst pins and rings. So all I have to worry about is the crank and mains....Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
The stock rods are forged.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
