how big boost can be handled with my stock engine. - FirebirdV6.com/CamaroV6.com Message Board
  • how big boost can be handled with my stock engine.
    i have powerdyne supercharger.. 97 firebird convertable..
    now i can see 6psi boost...
    yester day my friend.. who has tiburon(2000CC N/A full tunnig korea car )
    beated me..in quater mile..
    ^^; hehet~ i expected allready..
    but after i beated i feel a little bit
    angry..
    hmmm when i was getting close to
    finish line... my friend..car
    was getting fade out from me... ^^; sorry.. poor
    Englsih.. [img]smile.gif[/img]
    hmm my car's state was 6psi boost.. and....
    my girl friend.. was with me and i opend car..
    and i turned on pop up right and.. i have
    wooper and emp...capecitter.. atc in my trunk..
    its pritty big weight..
    hmm.. after i beated.. i thought..
    although my car is 3800CC i cantbeat my friend..
    at finish line.. between my car with my friend car
    distance.. was like 3cars...14Miter over..^^;
    but i thought again...
    if i dont open my car and drive alone...and..
    use 0.9-1.0psi boost and get rid of trunk's sound
    system.. i might can beat my friend...^^;
    how do you think about that?
    so today i got rid of trunk's sound system..
    it's weight was 60KG ^^
    after got rid of trunk's system... i felt my car
    can be moved sharplly..^^;
    anyway.. tomorrow.. i will make supercharger
    more smaller fully than stock fully..^^;
    i will make 0.9-1.0psi boost...
    how do you think about that? you guys...
    i need really somebodys help...
    in korea its just second time... having powedyne
    supercharger on firebird so...almost...
    nobody.. know.. about setup P/D on firebird
    hmm.. and i also.. having problem.. with P/D
    i grooved fully..so.. slip is noproblem..
    but when i start engine my rpm was goes up and..
    down... so just stop
    so i start again and then accelling....
    hmm...sometimes if i full accelling and then...
    if i dont touch accell my engine stop...
    why it happend... i cant understand..
    hmm..also i dont know. how TRC-1 works..
    i cant setting it...
    TRC-1 allways led right was showed..
    how i can use it...
    sorry..^^;
    and.. when i full acceling after 5000rpm
    the engine sound.. was very strange... i felt
    it might be detonated..^^;
    to explain..is not.. easy...with my english..
    sorry..
    to long ugly english... sorry..^^;
    0.9-1.0psi is ok? ^^;
    i need advice...
    thanks...
    p.s my car is automission..
    1997 firebird convertable.<br />intense 8.5:1 forged piston,rods,slp1.8 rockerarm<br />255welbro,28injectors,MAF,CIA headers,magnaflow exhaust,intercooled powerdyne S/C,TAXAS racing ECU tuning,coni shock with spring,roll bar,etc~
    I will try my best here :D First off, your motor is stalling when you let off of the gas (probably) because you have no or very little air coming into the motor. Is the blower tube that goes into the intake manifold TIGHT? Make sure the BELT is tight also, so that you can make 6-7psi of boost. I think the Tiburon is a mid-high 14 second car You should have been able to beat him. Also, do you have the stock exhaust still on the car??? If so, get rid of it (because it is restrictive) and upgrade the entire exhaust system so that there is no backpressure [img]graemlins/burnout.gif[/img]
    2004 CE Corvette 10.86@132mph
    2011 Cadillac CTS-V
    2006 Mitsubishi Eclipse GS
      how i can use it...
      How hot was it out??? Blown 3.8's do not like heat... as most other motors. You may have been experiencing detonation. The TRC lights up red when you are in boost. If it is a Crane module (like I have) you should set it on 2 and see if you get that "noise" you heard at 5000 rpm.
      2011 Cadillac CTS-V
        <blockquote>quote:</font><hr>Originally posted by woojong:
        ...and..
        <hr></blockquote>
        are you talking about boost or bar? b/c 1 bar is ~ 14 psi, and the P/D can't put that out. if you only use .9 psi, then what's the point of the S/C...i may not be understanding you, or may just not know anything about forced induction.
        stock engine will only handle 7 psi reliably...but can be pushed to 9-10 occationally
        [ September 07, 2003: Message edited by: mrbako ]</p>
        1998 Chevrolet Camaro L36 M5<br />1982 Toyota Celica Supra 7MGTE project car - FOR SALE<br /><br />\"I find the most sensual part of the woman is the boobies.\" - Zap Brannigan
          thanks.. about reply..^^;
          i have stock Exhaust system.....
          i know.. there is much restrictive exhaust...^^;
          so.. i hope i can change my exhaust system soon..
          to import is not easy..and its too expensive..
          hehet~ so im so sad... :(
          ^^; anyway.. hmm... sorry about confused
          1 bar between 10psi...^^;
          i didnt know 1bar is 14psi..^^;
          i meant 9-10psi..boost...
          and my friend car is right and..190r/w horsepower...and manual....
          i think.. his car might be 13's car...^^; in quater...
            I'm not totally following you here, but if you are asking about running 9-10 lbs of boost, it can be done. You will experience blow-by where oil will come out either your oil dipstick tube or somewhere else on the motor... therefore, you will need a crankcase breather system to run higher boost. You'd experience blowby at around 7psi and more.
            2011 Cadillac CTS-V
              shirl ^^; thanks..
              hmm.. mine is crane as yours..
              over 5000rpm the sounds like.. ddaddaddaddadda...
              ^^; can you understand?
              you said.. i should put dial 2 on TRC-1
              i think.. i havent put dial 2 on TRC-1
              do you meant if i put dial 2 on TRC-1
              over 5000rpm i can hear nois?
              at that time..if i hear nois...
              is it normal?
              can you explain again? ^^;
              intake pipe line is ok~
              i did everything tight...
              i can see 6psi....
              thanks...
              p.s) when i put 20 on TRC-1 and at that time..
              if i full accell my car... first gear is speed
              up...and..then when rpm is 6000rpm....
              it doesnt go secondgear quickly...^^;
              goes secondgear too lately....
              is it normal?
              i dont..know...^^;;;;;;
              thanks shirl
                If you set the Crane module on 2. This will retard the timing and therefore you should NOT hear that noise at/above 5000 rpm. If you still hear it, then there is definately something wrong. Ignition timing should be set at about 2 degrees of retard per 50hp. Each of those #'s on the Crane box retard timing by 2 degrees. For example: #1 means you are retarding 2 degrees of timing, #2 means you are retarding 4 degrees of timing and so forth. I have mine set at 1 1/3. Experiment and like I said, if you still hear that noise you were talking about, then it probably ISN'T detonation.
                2011 Cadillac CTS-V
                  shirl, did you have your kit installed in NJ?
                    Yeah, 6 years ago.
                    2011 Cadillac CTS-V
                      My head hurts.
                      !!!TOWN IDIOT!!!
                        To my knowledge, the most our engine can take safely is 9psi, without an intercooler. You can go as high as 12 with an intercooler. This is according to James.
                        As far as you fluctuating rpm, you might have a vacuum leak or your engine is not getting enough air.
                        I remember putting the Bosch BOV and the car was running fine. Then the BOV diaphram ripped the rpm was fluctuating at idle, because the air was coming off the hole.
                        But check for vacuum leak first.
                          I was thinking maybe the MAF screen is removed from the throttle body. Is this a pre-owned car, or are you the first owner? If you're not the first owner, check and see if the screen is still in there.
                          2011 Cadillac CTS-V
