i had detonation... on my car.. - FirebirdV6.com/CamaroV6.com Message Board
  • i had detonation... on my car..
    yesterday.. i had.. someproblem about my cars engine...
    something stragnge aharp sound was appeared from
    engine..and i could see smoke from exhaust...
    i think inside of engine.. has some problem...
    valve..or piston...seems to broken...
    i dont know if cause is powerdyne s/c or not.
    i think i have to spend over1500$ to fix my car...
    im so sad..and.. i am so confused that i have to
    install s/c to my car after fixing
    i have heard just with supercharger on stockcar..
    is safe...
    but..now. i dont..know...
    what made my car detonation...
    not yet~ i dont know.. what my car was broken..
    anyway.. sad... :(
    1997 firebird convertable.<br />intense 8.5:1 forged piston,rods,slp1.8 rockerarm<br />255welbro,28injectors,MAF,CIA headers,magnaflow exhaust,intercooled powerdyne S/C,TAXAS racing ECU tuning,coni shock with spring,roll bar,etc~
    What kind of gas are you running? I'm not sure how good the gas quality is over there. That might be why you are detonating so much? I run 93 octane in mine.
    2000 turbo/intercooled M5 Black Firebird<br />349.5hp and 415.3tq @ 4400rpms
      Well, see i told people this type of stuff will happen on our stock L36 engines. Your best bet is to rebuild your engine before you boost at all.
        Could probaly be his spark plugs. I had crazy amount of detonation with mine before I made them too heat ranges cooler. Never had the white smoke though. Hey Woojong, it's very possible that you just need new cooler spark plugs. Make sure you gap them at .35. Also come to think of it I did get white smoke from my exhaust, but it was actualy just my oil filter leaking because the powerdyne sits right on top of it and cracked it. The oil would leak down on to my exhaust while excellerating and for a while I also thought I blew somthing up. It only cost 5 $ to get a new oil filter and about 5 minutes to put a new one on. I find it very hard to beleave that you actualy damaged your engine. I personaly drove mine for 3 months with 7 psi and was only getting 45 pounds of fuel the hole time when I should have been getting 80 pounds. I also had my spark plugs gapped at .60 when they should have been at .35 and I still sufferred no engine damage. Well hope that is all it is ... GOOD LUCK
        Powerdyne 98 a4 convert<br /><br /> stock 16.6 @ 86 <br /> <br /> 6 lbs boost 15.1 @ 90 <br /> <br /> 04 A4 2.73 geared white Corvette Coupe<br /> <br /> stock- 13.5 @ 103 <br /><br />LS6 conversion-13.1 @ 107 <br /> <a href=\"http://members.cardomain.com/greenglow98\" target=\"_blank\">http://members.cardomain.com/greenglow98</a> ( pics of intercooled powerdyne)
          Two things are going on. You need to get your spark plugs at .035 for cold range. Get the NGK ones from tbyrnesmotorsport.
          If the Octane rating in Korea is lower than 91. You have to retard even more. Meaning, you have to adjust your TRC-1 or boost retardant to 3 or 4 depending on octane rating.
          If you ever get water/alcohol injection or other intercoolers, you can adjust it back to 1.
          If not then, you may need to keep adding a bottle of Octane every time you gas up.
          Keep us posted.
          Good Luck.
          [ September 11, 2003: Message edited by: Mighty Thor ]</p>
