Here we go againg :D . I am wanting to use a stock LSX LT1 MAF, now...I dont have HP tuners. What MAF can I use with out messing with the ECU? I am Runnung methanol injection and if my meth nozzle sees manifold Vac it will suck in meth at idle. I dont feel like buying a solinoid (or however you spell it).
MAF Question
you can't change maf's and not change the PCM program without adverse effects.
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
Originally posted by Russell:
you can't change maf's and not change the PCM program without adverse effects.If it cant Flow it, FORCE it!<br /><br />1999 M5 Camaro RS. Boost is on the way. Cartech FMU, 255 intank, T3/T4 BB 62-1 , Stage 5 turbine wheel .63 A/R.
The only way for a MAF to be plug and play is if the airflow versus frequency is scaled the same way as the factory MAF. And practically nobody would go aftermarket for a MAF scaled the same way as a stocker.Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
Is their a MAF I can use with out having to mess with the ECU. You know of any stock MAFS from other stock cars that will work?If it cant Flow it, FORCE it!<br /><br />1999 M5 Camaro RS. Boost is on the way. Cartech FMU, 255 intank, T3/T4 BB 62-1 , Stage 5 turbine wheel .63 A/R.
Originally posted by Turbo Kyle:
</font><blockquote>quote:</font><hr />Originally posted by HAZ-Matt:
Is their a MAF I can use with out having to mess with the ECU. You know of any stock MAFS from other stock cars that will work? </font>[/QUOTE]None that i know of. I ended up getting a new one cause i maxed the stock one. It's almost a must to have tuning capabilit if you are putting a turbo on the car. Otherwise, you'll end up ruinning too lean and that's not good.Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
yes but I don' think they are developing that for the v6s.
Originally posted by AllTheGoodNamesAreGone:
bleh.. again.. 2 & 3 bar speed density is where is gunna be at.. trust me..
The second problem is that it costs more $$ to get 2 or 3 bar SD support.
And lastly SD cannot compensate as well as a MAF.Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
How fast will you max out the MAF with a Turbo? Also when the MAF is maxed what does the ECU to the the Fuel curve? send the injectors to full blast?If it cant Flow it, FORCE it!<br /><br />1999 M5 Camaro RS. Boost is on the way. Cartech FMU, 255 intank, T3/T4 BB 62-1 , Stage 5 turbine wheel .63 A/R.
</font><blockquote>quote:</font><hr />Originally posted by AllTheGoodNamesAreGone:
And lastly SD cannot compensate as well as a MAF. </font>[/QUOTE]1) it will be out for the v6's when v2.0 of hptuners comes out from what I understand. If not then shortly their after.
2) it is more $$.. but thats how the world works..
i think its expensive at $300.. however if they sold it for $200 it is not bad considering is saves you the trouble of buying a MAF.. but god only knows what he pricing will be.
3) compensate, huh? for what? that sentence makes no sence..
regardless in the right hands SD is just as effective fueling wise as MAF.. you jsut gota keep an eye on it..
sorry if you feal like i am slapping you in the face with my huge e-cawwwk.. but yeah.. your wrong..
I see your point with SD tuning, The problem is that it appears (with my car anyway) the once i max the it drops the injector pulse to 7.1 No matter what was done it always did this. In my case a new MAF will make it easier to tune. I spent 150 on an SLP MAF Vs 300 on SD 2/3 bar. I'm good for 600HP. Until i exceed 600HP I'm not going to worry about SD tuning. I agree it will be needed just that it's easier to tune it with a MAF.Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
Hey Linxs, let me know how that new maf works for ya. I'm really curious from your other posts here and over at the hpt forum. good luck!
~Tom1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
Because a Speed Density system still has no sensors that directly measure engine airflow, all the fuel mapping points must be preprogrammed, so any significant change to the engine that alters its VE requires reprogramming the computer.
PS. It's feel.
[ February 19, 2005, 08:46 PM: Message edited by: HAZ-Matt ]Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
