ducting - FirebirdV6.com/CamaroV6.com Message Board
ducting
  • ducting
    I was looking for some replacement ducting for a whisper lid and stumbled upon this.
    web page
    This site has got me thinking maybe. . you could use this bendaway plus stuff for the hot side on a turbo set up. If you could it would make it so much easier. What do you gurus think about this stuff (seen it before?).
    1) kinda expensive at around $15 a foot
    2) its not smooth on the inside.. not smooth = bad airflow
    3) I wouldent reccomend it for the hot side of anything.. it may be able to hold those temps but see number 2.. and i have my doubts about that products durability on a car and its ability to resist bending cracking and the outdoor enviroment.. this is all not to mention the fact that its probably not designed to retain very high pressure..
      Metal? No way, unless it's solid pipe. Probably not designed to hold pressure.
        7 psi of boost = about ~14 psi of back pressure on a turbo car.....
        www.turbov6camaro.com
        1997 3800 Series II Camaro
