strobhen's information is incorrect...
There are two branches of superchargers: fixed-displacement and non-fixed displacement. Fixed-displacement (Roots, twin-screw) pump a specific volume of air per revolution and do not permit reverse flow. Air comes in the inlet port and then the port closes. The air is moved to the outlet port, that port opens, and the air discharges. At no time, and regardless of pressure, can air go backward through the supercharger.
Non-fixed displacement superchargers (centrifugal) push an unspecified amount of air along, much like a fan blade, so air can flow backward if conditions warrant. Nothing closes to block the flow. Only air being pushed by blades, much like a propeller, influences it to travel toward the engine. If boost at the compressor outlet suddenly gets too high, as when the throttle (downstream of the supercharger) is slammed shut at high supercharger impeller speed, the air can reverse directions and go right back out through the compressor, just as air could flow backward through a propeller if a great enough force were pushing it.
<blockquote>quote:</font><hr>Originally posted by strobhen:
The impeller doesn't compress air, it just moves a lot of it.<hr></blockquote>
Centrifugal and twin-screw superchargers have internal compression ratios, Roots do not. A supercharger with an internal compression ratio is one in which both volume and pressure vary as the air passes through. As the bit of air passes through, it is continuously forced into a smaller volume, which also increases the pressure. Upon reaching the discharge port, it's already compressed.
Of course superchargers compress air... they're called "compressors" for a reason.
Even Roots "blowers" compress air, only in their case the compression occurs after the air is discharged into the intake manifold.
There are two kinds of superchargers. There is the "Roots" supercharger. It is a twin screw design that makes a lot of boost down low, and is mainly used on carburated & OEM applications. They are torque monsters and spin up very quickly. The other kind is called a Centrifugal Supercharger, which is basically a belt driven turbo. It is more efficient than the roots, less than the turbo, but also has less lag than the turbo and is a tad cheaper.<hr></blockquote>
There are three types as described above, and they fall into two categories. Each has it's own unique advantages and disadvantages. On F-Body applications centrifugal is by far the most common because of simplicity of installation and price. Twin-screw is superior but the engine must be designed with the supercharger in mind--a screw supercharger is hardly a direct bolt-on.
<blockquote>quote:</font><hr>Originally posted by Arctc Wolf:
when installing a sc kit, the kit will give you instructions as to how and when to put a part on, as well as give you all the components you'll need.<hr></blockquote>
Good advice for the original question. Key word being "kit"!
No, a supercharger does not compress air and then spit compressed air into the engine. It is a very powerful fan that spits a lot of uncompressed air into an engine -- the only reason air in the engine becomes compressed is because it cannot move the air out fast enough.<hr></blockquote>
In a centrifugal supercharger, the air is compressed before it even leaves the discharge port of the supercharger. A supercharger does NOT simply push "uncompressed" air. You know the snail-like outer housing of a centrifugal? The cross-sectional volume of that snail path is ever-decreasing, thus the pressure is ever-increasing until it reaches the discharge port.
There is nothing in the mechanism to compress the air. Air is compressed in the engine because you have an engine that puts out, say, 500 cfm of air and a supercharger that pumps in 1000 cfm of air. Where does that other 500 cubic feet of air per minute go? Nowhere, so the incoming air must compress it to make room inside a static container. Very little if any compression takes place in a supercharger.<hr></blockquote>
That right there is just plain wrong. There IS something in the supercharger to compress the air--it's entire design! They're called compressors for a reason! If you don't believe me, pick up a book about it and READ! Don't sit here spewing out incorrect information. As I said at the top of my post, you are thinking too much and confusing yourself. The gist of what you're saying is correct but your logic with regards to compression are incorrect.
<blockquote>quote:</font><hr>Originally posted by daWhoady:
I guess I was mistaken. strobhen, you explained it beautifully.<hr></blockquote>
No, strobhen is confusing himself and others.
[ July 07, 2002: Message edited by: Stefan ]</p>
