Injectors and fuel pump... - FirebirdV6.com/CamaroV6.com Message Board
  • Injectors and fuel pump...
    Hey all. For the time being, can I use my 36lb. injectors with the stock fuel pump to run my 7psi of boost? Or should I put my fuel pump in now? I just really don't have the time before I have to bring this thing to school to show it to my professor for a grade....Just let me know what you guys think.
    ~Tom
    1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
    i would say try it if you had tuning and a WBO2 but you dont have any way to see if your goign lean i would say change it out
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      I have a wideband and I've got hp tuners...c'mon man!! you should know this by now!! haha...so i think i'm gonna give it a go for now. What size silicone reducer fits over the throttle body opening on my 97 3.8 intake? I measured about 3.75 but can't find a 2.5" to 3.75" reducer....erggg
        i thouhgt is was 3.5 ????
          yeah its 3.5 my K&N is that size
            A 3.5 is probably the best bet so it fits nice and tight. Good call. So you know where i can get a 2.5 to 3.5?
              what do you think of welding a metal transition from 2.5 to 3.00 right before the intake in the intercooler piping...then do a 3.0 to 3.5 silicone reducer...might make for slightly better flow over the maf?
                You could also do that with silicone.
                01 Camaro A4 Convertible
                  Unless i put some sort of support ring inside the point where the two silicone connectors meet, it would just collapse when you tightened the clamp. I was thinking of that before but it doesn't seem feasible...
                    ebay has both elbows and reducers and reducing elbows. there are a few main sellers. one of them has real cheapo stuff but one of them has reinforced silicone.
                    search ebay, turbos/turbo parts...'silicone' or 'reducer' or elbow' . hits will pop right up.
                    the ones in above provided link by 'south tampa' are supposed to be real good. a little pricey for some of the pieces...they did not have the elbow I needed to I had to go ebay. no problems at 6 psi.
                    01 Firebird A4 3.42
                    Powerdyne @ 6 PSI
                    and other mods
                      Thats how I originaly set up my intercooler. A 2.5-3in reducer with the 3in side sleved with some 3in exhaust pipe, then clamped a 3.5in radiator hose over that. It worked fine. Probably not the most accurate MAF readings ever though.
                      As for the original question, I'm still running the stock pump w/43lb injectors, since september.
                      Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
                        Uhm, yeah, so I got my 3.5 to 3 reducer today and that thing is nowhere near gonna fit over the throttle body opening. I took the caliper to it today and its measuring 3.75 over the outside edge. The only seller i can find of a 3" to 3.75" is the one i bought these from, but this reducer he sent me was like 2 inches long...it'd be horrible for getting over the tb and the pipe. Anyone have any ideas....phoenix, you mentioned radiator hose??? but you used 3.5???? HELP!!
                          Yeah it takes a lot of streching and prying with a screwdriver to get it on, but the hose is pretty thin so it streches quite a bit. I'm 99% sure the I/D is 3.5, but I could be wrong.
                          Is it silicone or rubber? Is there anyway you could heat it? That might expand it out a little bit, as well as make it more flexible. Just a thought.
                            boil it in water and run to the car !!!!!!!!! should be easier
                              ok, well either way the d bags sent me the wrong size, only 3.25...not to mention they cut it like 2 inches long...there is no way that'd go on and leave me enough room to get the pipe in the other side...anyone know where i can get a different one...maybe longer. I've been seeing on tiagos kits they use a pretty big one...you know where i could even find that?
                              ~Tom
