I'm installing the fuel pressure gauge for the powerdyne and need to know where I can buy an adaptor for the pressure sender to the Schrader Valve. Has anyone done this or know where to buy one?
fuel pressure gauge question
Oh man....lol, when I did my install, I wasted an ENTIRE day looking for that damn fitting.
I finally got the hose as well as the two different fittings that are required to put it togeather.
Check at the local Home Deopt, as well as Lowes...and if like me they have nothing, try at all the Hydraulic shops. They are the ones that ended up with what I needed.
And prepare to sit before they tell you the cost as well.... :eek:
U can get them from summit i believe for like 5 dollars
i will post a link when i find it.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
The size is 4AN on the schrader valve, do it the safe way and buy an Earl's fitting from Summit. Do you know the size of the sender fitting? I THINK the autometer one is 1/8 NPT. It's in the instructions. After I bought a fitting and a line I found that NOS makes a line with 4AN on one end and the NPT size on the other that would have worked perfect.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
