how much boost does your PD or othe SC make at 3000 RPM?
SC peeps
SC peeps
www.turbov6camaro.com
1997 3800 Series II Camaro
Tags: None
I think mine is at 5 psi, then goes up to around 9-10 and levels off at 8 psi. This is with no intercooler.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i was just want some numbers b/c alot of people brag on turbo lag... but if the turbo fully spools (hit the set PSI) at 3000 rpm I can see how the SC motor would get al ittle jump in the lower RPM but soon as the turbo spool i think it would atleast make up for it if not more....www.turbov6camaro.com
It also depends what gear you are in, 1st gear I can see 5-7 psi at 3000 rpms but if I'm in 2nd and get on it at 3000 rpms I'll hit 8-10 psi. 3rd gear is about 5-8 psi.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Here is a link to a thread at clubgp talking about when different turbos spool. Most start spooling around 3k and are fully spooled around 4k. The only problem is none say how much boost is fully spooled.
Clup GP Spool Thread92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
well linxs's t-70 is fully spooled (5-10 psi) at 3000 PRM so...... i'm just board and cerous ... hehewww.turbov6camaro.com
with a 6lb pully on a powerdyne you basically get 1psi per 1000rpm. centrifugal SC's are linear so its really easy to see how much power can be achieved at each rpm.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by viper04af:
i was just want some numbers b/c alot of people brag on turbo lag... but if the turbo fully spools (hit the set PSI) at 3000 rpm I can see how the SC motor would get al ittle jump in the lower RPM but soon as the turbo spool i think it would atleast make up for it if not more....Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
Originally posted by phoenix64:
</font><blockquote>quote:</font><hr />Originally posted by viper04af:
</font><blockquote>quote:</font><hr />Originally posted by phoenix64:
he is trying to say you are slow in the head. (dont shoot the messenger)2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by T-Punk:
he is trying to say you are slow in the head. (dont shoot the messenger)www.turbov6camaro.com
Centrifugal is more linear than anything. Awesome for top end for most Centrifugal SC. PD is a little unique. Boost can start early and work it up to redline. SC like Vortech and ATI you start seeing the boost at around 2500-2800 rpm and then be at full boost at around 5000 and over. Ofcourse, the smaller you go on the pulley the more immediate the boost gets.
Wipple SC is the best. You can be at full boost at around 3000 rpm or even lower. Boost starts the moment you turn on the engine. That's why it's Corky Bell's favorite force induction.
