You have to have the properly sized turbo to counteract the cooling gasses. Read the first link addresses the formula's to compute the needed sizes for different set ups, taking into affect the exhaust temp and pressure on the inlet side of the turbo housing.
http://www.turbobygarrett.com/turbob..._techinfo.html
http://www.turbobygarrett.com/turbob...urbospeak.html
I do agree with you about smaller pipe limiting top end performance. I was just confronting the issue of turbo lag. You'd of coarse want to find the best middle ground. You can't have high boost numbers at the top end and no turbo lag at low rpm's, or vice versa.
