No you can blow the doors off an Ls1, LT1, Honda,
Nissan, import or whatever you race against in loo of the fact that you are using boost and maybe they are not. Regardless of what system you use fine tuning and boost are not limited to the turbo, heat, design, etc. The limits of your pocketbook and engine capability determine how well you will boost. Trust me, if you research the system (assuming you don't really know that much about turbos) you will find that tuning is
just as easy with a front mount and still easier than supercharging.
