alright i got the pcv fixed and the belt tension but now it keeps blowing my discharge elbow that goes into the throttle body off, I am usind regular hose clamps is there anything out that would work better it will only let me see 4lbs then BAM it pops off and is a pain to put back on
Hose Clamps
one thing i learned about the powerdyne is that you have to tighten the living SH*T out of EVERYTHING..are you using a BOV?..and what is your exhaust like?..i had a hollow cat and open muffler (borla) when i had my blower on..i cant really think of anything else to use..im not sure if you would want to use some sort of adhesive there..theres obviously too much back pressure..i would think..check out a breather..BOV..and your exhaust<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
There are clamps out there called T-bolt clamps or something like that, that are supposed to work better than regular worm drive clamps for boost applications.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Originally posted by Rob Bell:
There are clamps out there called T-bolt clamps or something like that, that are supposed to work better than regular worm drive clamps for boost applications.If it cant Flow it, FORCE it!<br /><br />1999 M5 Camaro RS. Boost is on the way. Cartech FMU, 255 intank, T3/T4 BB 62-1 , Stage 5 turbine wheel .63 A/R.
The BOV will help a bunch in venting the pressure out to the atmosphere instead of it trying to blow off your pipes. Cheap enough -- you can get 1G DSM versions for $30 or so. (or, as I like to say, go ahead and spend $250 on a HKS one)<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
If it's blowing off at 4 psi, the elbow is probably not seated all the way, or the clamp is overlapping the ridge instead of setting behind it, or the inside of the elbow is slippery for some reason...
I'd eliminate all those possibilities too.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
