LATEST UPDATE 07/18/02 - FirebirdV6.com/CamaroV6.com Message Board
  • LATEST UPDATE 07/18/02
    A dyno was done on my car before anything was put on to make sure my engine was running fine.I had the dyno done at Speedworks and they took my car up to 6200 RPMS.At around 5400 rpms, and 76MPH i got execive Pinging.The curve on the dyno show a normal climb, then a weird drop at 5400, then a sharp drop at 6200.
    Here are the problems with that.
    I had a dyno done at speedwork once before a long time ago... about 1 yr ago actually, and I got 185HP @85 MPH.
    However there is a good explanation to what is happening. When i had the first dyno done last year, it was with a Jet Chip. The first run was made with the Jet Chip, and the second was done without it. However we all know that pulling out a Jet Chip isn't going to reset anything right away.
    I can't remember, but i am sure the Jet chip compinsates for thermostat, changes shift points and raises the limiters.
    I also had another problem back then which was the fact that i had changed the gears. The Dyno shows that i hit 185HP @85Miles an hour and i got cut off, at 4200RPMs. It hit my speed limiter early because i had my gears changed. That particular run was done in 3rd gear and Greg at Speedworks told me that he had made changes in the dyno to compinsate for my gears.
    Now back to the present situation. With all that said, This time they made the runs in 2nd gear.
    What Bill believes happend is that this time my car hit the rev limiter at 5400 rpms (As it should) and cut the fuel off which would explain the excessive pinging. We drove the car and drove it in first and if any of you have done this before, you will notice that in 1st gear that the fuel is cut off right around 5400 RPMS, at this point you can hear the car as if it was in nuetral (fuel is cut off) and then it just hangs there as it (which would explain the drop in the curve after 5400RPMS) revs up to 6200RPMS at which point HP and torque dropps (which would explain the sharp drop at 6200RPMS).
    Bill is pretty condfident that my car is not pinging, but that it is just hitting the rev limiter. However not to take any risks, he wants to be sure he is right without a doubt and wanted to do the cal on my pcm to raise the rev and speed limiter. IF he raises the limiter to 6000RPMS, then the new dyno should show pinging after i hit 6000RPMS. If i still get pinging at 5400RPMS, then there may be an issue.
    He is also making sure that the new cal tells my PCM that i have 160 deg thermostat and 3.42 gears.
    Right now my car is running very hot. I used to have a 180 thermostat in and i thought it ran pretty hot then, well its running even hotter now with the 160 stat. He said that changing the thermostat to 160 and not calibrating your PCM won't do any good... infact it can make your car run hotter.
    Here is why: Your PCM is programmed to open up at 195 (stock thermostat) and allow coolant to run through the engine and radiator. Your PCM is also programmed to turn your fans on at a certain temp 210 i think. Normally the coolant gets time to cool down in the radiator because the fan is on and then the cooled down coolant runs through the engine making it cooler.
    However with the 160 thermostat. The pcm opens the coolant up at 160 letting coolant run through the engine. However the PCM is still programmed to only allow the fans to turn on at 210 which means from the time that my car is 160 till i reaches 210, the coolant is not being cooled down in the radiator because the fans aren't on. So basically i am running hot coolant through my engine.
    Make sense? Of course when he explained it to me i had my doubts cause i remember when i had the 180 stat in, my car wasn't running as hot, but then i remembered i had the jet chip inside my car which reprogrammed the pcm to compinsate for a 160/180 thermostat. The Jet Chip isn't in my car anymore so now my car is opening up at 160 and not being cooled till 210.
    The gears are also messing things up. Because i originally had 3.08 gears and now i have 3.42 gears, i keep hitting the rev and speed limiters earlier than what i am supposed to be hitting it at. On the way back from Maryland from the shoot out i tried to see how far off i was in my milage reading. Well i found that my trip meter showed me hitting 1 mile mark 1/10 of a mile before i actully hit a mile. So since i have 40000 miles on my car its safe to say that it is very possible that i have 4000 mile on my car more than what it really has. WHICH SUCKS Cause it means i would still be under waranty if i hadn't changed my gears. UGGGH.
    Anyways...
    BIll does not want to slap a blower on a car that is pinging, cause he doesn't want my car to blow up [img]smile.gif[/img] i am glad he doens't want to do that either.
    SO he got the cal from the GM engineer and they tried it, and well.. .my car wouldn't even start. They looked over the code and the Engineer knows exactly what is wrong, but before he makes the change, he wants to consult another engineer who happens to be on vacation about the differences with a 2000 PCM and other years. He wants to learn everything there is to know about an Fbody V6 PCM. Bill said he will have the new cal on monday.
    For the time being, Bill went and downloaded the latest cal from GM for a 2000 firebird and put my car back to what it was. My car is running fine with no problems [img]smile.gif[/img] Probably even better since I now have the latest CAL. I bought my car in 1999 even though it is a 2000 and i am sure i had V1.0 of whatever Cal they had for the 2000 Firebird back then. JUST Thought i would mention that so you guys don't think he broke my car [img]smile.gif[/img]
    Bill is confident that the new cal will work.
    In the mean time he took all the mesurments he needs and he is now working on the bracket and the duct work [img]smile.gif[/img]
    Regardless of hicups which should be expected, things are moving forward.
    [ July 18, 2002: Message edited by: BATMAN ]</p>
    - Ryan<br /> A.K.A BATMAN<br /> \"Be part of the solution...<br /> Not the problem\"
    good luck with that [img]graemlins/thumbsup.gif[/img]
      good to see he is putting a lot of effort into the work.
      2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
        Good luck, Keep us posted.
          Sounds good. Please keep in mind its not the lower temp thermostat that causes the problem with the car not wanting to cool off, or the fact the fans dont turn on soon enough, its the fact the radiator is TINY. If you were to upgrade to a griffin twin core for $450, your whole car would idle at a little above the temp the thermostat was at (i.e. a 180 should make the car run between 180-190 and the fans shouldnt even kick on).
          Again, goodluck with the supercharger. When I had my car dyno'd (A4) the guy REFUSED to dyno it in any other gear but 3rd (1:1) claiming my horsepower numbers would be all fubared (umm, no?) but anyways thats kinda strange. Did you try dynoing it in 3rd at all?
          [ July 20, 2002: Message edited by: Dominic ]
          [ July 20, 2002: Message edited by: Dominic ]</p>
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            I like Bill, couldnt of picked a better person. I think he does his work pretty thoroughly, and I like that. Let's me know I'm buying a qualitly product that was excessivly tested [img]smile.gif[/img] In this case, excessive is good! thanks for the update batman.
              Yeah, thanks Ryan. Being that I'm one of the 10 beta testers, its good to know that alot work and concern are going into our superchargers and cars. Good luck with the rest of the Alpha testing and keep us updated.
              Chris
              1999 Firebird <br />Y87 Performance Package<br /><br />Borla exhaust, 3\" Catco Cat and 3\" pipe throughout, RK Sport Headers, K&N air filter, SLP CAI, Whisper Lid, 36 lb Injectors, ATI 3.8 Intercooled Procharger Kit.
                Upon rereading it again, something doesn't make sense. You said it hits the rev limiter at 5400, but yet they dyno it till 6200. If you hit the rev limiter it would not allow you to go past 5400.
                Is Bill the PCM guru? Can you email me some contact info for him? I need to have a long discussion with him. :D
                I hope to get this figured out. That before and after dyno graph would be priceless.
                You're still on stock internals right? Stock injectors and fuel pump?
                Good luck! [img]graemlins/thumbsup.gif[/img]
                [ July 19, 2002: Message edited by: Dom ]</p>
                  wtf is up with the 5400 rev limiter? are our tachs that off..mine shifts when the needle is about at 5900
                  good luck
                    <blockquote>quote:</font><hr>Originally posted by Dom:
                    <hr></blockquote>
                    Yeah.... that part didn't make sense to BIll either.... he was like...
                    Why the hell are they taking it up to 6200 if they know your hitting the limiter at 5400? Since he wasn't there, he can only make assumptions.
                    he wants to be sure nothing is wrong with my car before he slaps that blower on.
                    See... even if you hit the limiter... it does let you keep going... not sure if you have a manual, but i have an automatic.
                    When i hit the limiter... it just cuts my fuel, i can still hit the accelerator up to 6200 RPMS.
                    Put you car in first and then just accelerate, when you get to 5400 RPMS keep acclerating and you will see what i mean... Again i am not sure how this works on manual, i am only speaking from an automatic trans point of view.
                    i will scan my dyno this weekend and show you guys what i am talking about. I will also try and find the first dyno i had done to give you guys a better picture of what i am talking about.
                    [ July 19, 2002: Message edited by: BATMAN ]</p>
                      Ya, you can very easily hit & pass the rev limiter in an auto.
                      But then again, recently after I had my tranny repaired from slippage, I haven't had as much of a problem w/ that.
                      I thought the rev limiter would be above 5400 based upon where I see my needle stop moving, hehe
                        I have an auto. When I hit the limiter sometimes at 6K it bounces me back to 5800 and keeps bouncing forever until I let off the gas and let it shift.
                        I though everyone had a 6K limiter stock.
                          Yep. My rev limiter strikes in at around 6K.
                          5400 RPM? wtf? The tach shows the little red dashed area as soon as you hit 5500 - but... I dont hit limiter until 6.
                          [ July 19, 2002: Message edited by: Cale ]</p>
                          2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
                            I might be hitting it early because of my gear ratio.... then again... who knows...maybe i am getting pinging. :(
                              Auto's dyno in thrid with the converter locked up
                              Manuals dyno in fourth
                                4 days ago
