How long does it take to install? - FirebirdV6.com/CamaroV6.com Message Board
  • How long does it take to install?
    The powerdyne that is...I cant find any exact hours through the search.
    I think I will install it and try to run the 6lbs and then later go back and do the 10lbs.
    [ full bolt on\'s and blown.]<br />[formerly known as naptown]<br />[just know that im teh man ]
    shouldn't be more than a few hours but make sure you have a full day incase of problems.
      yup..no more than an afternoon..and thats with EVERYTHING..as i've said before i ran 6psi with nothing but the bolted on blower (no FMU or timing retard..just 93 octane fuel..which of course i am not recommending) and that took me about a 1/2 hour!
        So if I went and got like say some C16 and bolted the blower up I should be fine with racing it at the track?
          C16? you dont even need that, 93 octane should be fine, especially if you retard the timing. 6psi is pretty safe.
            I dont think the kit comes with an ignition retard...
              They do.
              It takes more than 6 hours.
              it takes some people 2 to three hours just to change the spark plugs or to disconect the fuel lines.
              do all the prep mods first...john_d wrap, PCV bypass, fuel pressure gauge, install FMU, install timing retard module, start running premium fuel before you intall the blower. Dont forget you will need a 2 claw pulley puller and suggest ngk tr6 plugs gapped to .035.
              Check out my website. I have a whole section of guides for installing and running the powerdyne.
              good luck. g
              01 Firebird A4 3.42
              Powerdyne @ 6 PSI
              and other mods
                Oh, wait... you have the john d kit, right? Yea, I don't know if you have the timing control module with that.
                You can still do all the prep mods before hand.
                I seriously recommend a fuel pressure gauge.
                01 Firebird A4 3.42
                Powerdyne @ 6 PSI
                and other mods
                  Wideband and Fuel Pressure gauge has been ordered as well as the hptuners.
                  [ March 27, 2005, 07:00 PM: Message edited by: Just Another V6 ]
                    The unit itself is very easy. But the FMU is more of a challenge. I messed that up big time and had to have someone install it for me.
                      Hea, this is exactly what I want to do to my 99 bird. 3.8. Do you need new injectors, or a new fuel pump? I wanted to bolt something up to my stock 6, and get some results, but be able to drive it anywhere, anytime. Like back to my home state of Kansas, or just around town. I dont want to blow it up. Please let me know if I can do that on a stock motor. I'll follow this REAL close. Thanks guys, [img]smile.gif[/img] Jessica
                      Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
                        Jessica: 6 psi is no problem. that is what comes with the rksport powerdyne kit. you will not need new injectors nor a new F-pump for 6 psi. You will want to add a fuel pressure gauge.
                        my mpg is the same but the car has a great deal more power.
                        with the additional 'powerdyne prep mods' you will be golden.
                        if you also have aftermarket exhaust you will get more out of the powerdyne. (for starters...there is always more you 'can' do...but good exhaust is pretty big deal when compared to simplicity and affordability of new exhaust.)
                        Add a powerdyne and you will think you are driving a 'red barcheta.'
                        p.s. don't follow 'just another v6's' threads too closely. He has a rather modified (and famous) powerdyne kit that he is installing. It is more involved by far than the average 6 psi powerdyne.
                        [ April 01, 2005, 04:07 AM: Message edited by: grayman ]
                        01 Firebird A4 3.42
                        Powerdyne @ 6 PSI
                        and other mods
