u might need tuning to run them. if u go 75-100 miles w/o an ses light, ur good and ur car has learned how 2 adjust the flow rate to what it needs. if u do get an ses light, u'll need 2 get the pcm tuned so it knows u have bigger injectors.
if teh computer makes a few littel sputters here and there you may be able to play with fuel pressure a bit to control it.
the ultimate answer woudl eb to get programmed though.
Originally posted by woojong: 97 3.8 bird convertable...hehet~
and i have a question..what is my gear ratio? ^^;
mine is stock gear....hehet~
Open your driver side door. On the side panel there is a sticker that has number and letter codes. If you have Y87 and GU6 then you have a 3.42 gear ratio. If not, then you have 3.08 gear.
Question, is your pulley smaller than the original? What is the size in inches ( I know in korea you have metric)? What type of belt are you using?
If you got 3.42 gears then that is excellent. That's an ideal gear for us.
Some people some changed gears here and have had bad experience with it, especially with speedometer and the limiters. You're better off in investing your money on tires than on gears.
