Knock Retard limit for SC - FirebirdV6.com/CamaroV6.com Message Board
  • Knock Retard limit for SC
    Hey all,
    Have started running autotap logs for a good portion of my trips and wondering how many degrees of Knock retard will cause problems with an SC setup? I need to get anything fixed before the beta kit comes out. I'm running at pretty much zero, and occasionally, I get from .02 to just over 1 degree over knock retard, but they are very minial. I can provide autotap logs/config files if anyone cares to take a gander.
    Thanks,
    Steve
    2000 Magnetic Red II Automatic Coupe
    Best(s): Coming soon
    99 Bright Red Turbo Firebird A4 T-Tops
    Best(s): N20 - 14.01 @ 97.32 (1.64) Turbo - Coming soon
    0-1 KR is very minimal, nothing to worry about. If you start seeing numbers like 5-7 or higher then look for some possible problems. I ususally get around 1 deg of KR when I shift gears from the tranny shock.
    Right now I'm having good luck with 6lbs of boost, I don't have the ignition retarded at all and the plugs are gapped at .035 and I have 0 knock.
    Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
      Cool.. just what I was hoping to hear. I think the max value I've seen so far is 1.2 .. I've only recorded on two long trips, however, I have noticed that it does typically show up during the auto shifting.
      Thanks ;)
