i am planning to wrap up the rebuild of my engine and wanted to know if the egr valve has to be deleted due to the powerdyne possibly causing the egr connection to the intake to pop out during boost
will egr blow off
will egr blow off
3\" Eldebrock catback exhaust<br />rksport powerdyne<br />pacesetter headers<br />VS cam,compcams pushrods,ls1 valves,5 angle valve job,p&p,<br />and total seal piston rings<br /> <a href=\"http://www.cardomain.com/ride/804031\" target=\"_blank\">http://www.cardomain.com/ride/804031</a>Tags: None
be for the EGR pops of your block will explode and your run you motor over......www.turbov6camaro.com
1997 3800 Series II Camaro
[img]graemlins/rofl.gif[/img]
