Will it fit in my car without alot of exspensive work?
Will a GTP's super charger work on my 3.8?
This topic is closed.
My 1996 Camaro RS <a href=\"http://www.cardomain.com/id/mustangkiller311\" target=\"_blank\">www.cardomain.com/id/mustangkiller311</a> \"Its out-dated\"<br />Mods=SLP CAI, 3.42/LSD, 180*, BMR StrutBrace,SLP Take-Off Shocks/Springs, Z28Swaybar, DynomaxSuperTurbo,3in pipes,Catco3in,3in Cutout ThrottleBody Spacer, SolidDriveShaft,NGKplugs, Taylor8mmWires,ZR1 rims, RS Spoiler,WhiteFacedGuages.<br />Stereo= Pioneer DEH-P8400MP, Custom Subthump enclosure, 2 BlouPunkt 12\'s, JL 500/1, Fosgate speakers, 1FaradCap.<p>NEW 1997 FireBird Formula WS6Tags: None
Way to be hospitable to a new member.
What he meant to say was, there is a lot of information already posted on this topic. I'm sure if you do a search, you'll get all the information you need.
Good luck.
[img]smile.gif[/img]1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
Nope won't work. Look under your hood at the intake manifold, see how much room there is above it? The Eaton supercharger is much taller than that so it won't fit under there. Now notice that the 3.8 L67 (the supercharged 3.8) is in a front wheel drive car. That means the that the way the engine sits in the car the belts are on the passenger side, not right in front like ours. If you've ever seen the Eaton supercharger, one side has the pulley, the other side is the intake + throttle body. If you put that on our cars, the pulley will be right up front with the other belts and the intake will be all the way in the back of the engine. Definetly no room for our throttle body so it would need lots of custom work(expensive) even if you could get it to fit under the windsheild.
The SEARCH feature is very, very useful when it comes to questions like this. This supercharger was put on a f-body for a SEMA auto show with the help of a lot of money and custom work. You'll find that information if you search.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
