I know there is alot of topics about this kit but I am just wondering if I put a magnaflow exhaust system on my car then put the turbo kit on would there be any problems with this set up. Like would I have to change the exhaust or anything like that. Also wondering if it is better to get new headers or keep the stock exhaust manifolds. I asked tiago and he said to keep the manifolds but that doesnt seem right ot me. Any input would be great
fff turbo kit exhaust
tiago made the kit so i think hes right [img]graemlins/stickpoke.gif[/img]
what year its your car?
EDIT i see you have a 2002
if you get headers the kit will not fit and the gian of the headers is not worth price, you mannies flow really well already....www.turbov6camaro.com
1997 3800 Series II Camaro
like viper said, the 02 manifolds flow good and the kit is made to fit those manifolds. The cat back is fine, wont affect the kit.
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
Originally posted by GN-T66:
The better flowing a manifold/header you run on a turbo kit, the better. headers will flow better than factory manifolds, tubular or not.www.turbov6camaro.com
after hearing shanes turbo system with an open down pipe i have come to the conclusion that a muffler is not a neccessity with a turbo. It sounds like a LM or Rumbler almost. That said if you dont want an annoyingly loud car i would run a cat back just to tame it down some more. As for Tubulars vs. headers, there is deffinately some power to be gained from the headers but it wont be an astronomical gain and to me is not worth the money or the hassle of putting the headers on (bolts have been know to break when removing the manifolds) unless you want to get the absolute most out of your setup. It is up to you, look at the pros and cons of everything before you go ahead with anything.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Header would make a little more power. I am running a Turbo on my 99 Camaro with stock manifolds, Im not sure how good they flow.
However,
I think headers are over rated for our cars when turboing. A small 1 5/8 header will support 1500 HP on a V8 car. Most V6 guys here are making around 500 HP. I think manifolds are plenty.If it cant Flow it, FORCE it!<br /><br />1999 M5 Camaro RS. Boost is on the way. Cartech FMU, 255 intank, T3/T4 BB 62-1 , Stage 5 turbine wheel .63 A/R.
I hacked off my muffler. I'll see how it sounds with just the striaght pipe after the cat and see if I want to put a better muffler with 3" piping on or not once my tranny comes in.1996 Camaro, Built Motor(L/C,Cam, Ported), T66 FFF Kit, N20, 36 lb. Inject., FMU, 255 Walbro, 00+ Manifolds, SFC, LCA, Tubular K, Adj. PHR, 17x9.5,x11 Chrome ZR1, Front 35MM/Rear 21 MM Swaybars
However,
I think headers are over rated for our cars when turboing. A small 1 5/8 header will support 1500 HP on a V8 car. Most V6 guys here are making around 500 HP. I think manifolds are plenty.www.turbov6camaro.com
Im not saying you wrong Viper. Ill let you **** your own pants when you see my Dyno numbers with Stock mannies :D
Remember 1500 HP on a 1 5/8 header. We are not making near that.If it cant Flow it, FORCE it!<br /><br />1999 M5 Camaro RS. Boost is on the way. Cartech FMU, 255 intank, T3/T4 BB 62-1 , Stage 5 turbine wheel .63 A/R.
unless you have the tube one's installed i bet you log one's glow after hard drivingwww.turbov6camaro.com
We will see what happens. BTW could I just switch out my mannies for some 2000+ one with no mods to my Y-pipe?www.turbov6camaro.com
