What is better on the engine a supercharger or a turbo, and do they even make a turbo that can make 15 lbs of boost that will fit 99+ 3.8? I want to do a project and see if i can get a turbo on but I don't know how hard it will be to get my pcm programmed right so i won't get really really bad gas mileage. If anyone has any thoughts on how to get started on this please post. This may take awhile since funds aren't available at the time.
Supercharger or Turbo??
1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>Tags: None
do a search. this topic has been discussed numerous times in large discussions. You will have all your questions answered.
In short, no turbo system for your car, has to be custom, and you can get 15lb of boost out of a turbo, you just have to find one that compliments your engine the most by using a compressor map.<b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
Thanks, I didn't find much on the turbo so that's why I posted.1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
the turbo is the way to go. its more efficent. the turbo robs 5-10 hp as opposed to the super charger which takes 70-100hp to spool up. the turbo also alows higher boost.Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
<blockquote>quote:</font><hr>Originally posted by phoenix64:
the turbo is the way to go. its more efficent. the turbo robs 5-10 hp as opposed to the super charger which takes 70-100hp to spool up. the turbo also alows higher boost.<hr></blockquote>
You're right in a way and wrong in a way. Turbo's are more efficient and they have less parasistic loss to spool up, but supers don't take 100hp to run. Some of those big *** roots type blowers take hundreds of hp to run, but a small centrifugal SC at low boost will probably take around 50hp.---<br />-\'95 3.4L M5 Camaro
Thanks guys I will search more in depth to find a good setup I can use.1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
