Spark Plug Wire debate. - FirebirdV6.com/CamaroV6.com Message Board
  • Spark Plug Wire debate.
    Im debating on what ones to get.....I need something that would be good for a FI car and can stand lotta heat.....I was looking at Taylors, Magnecor KV85, and MSD's.
    What you think?
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    I like Taylor the best. I've tried Magnecor before but on the 89 and it was OK.
      I vote for Taylor wires as well.
      1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
        I dunno.. I kinda don't like the bulky Taylor ends, they seem to trap and keep heat for a while. That being said.. I do run them on both our cars with minimal fuss. :D
        ________________
        Rob
        1994 Firehawk#319
        11.83@120.61
        Slightly Modified
        1996 Blown V6
        2002 Trailblazer
        San Diego F-Bodies
        "Garp bit Bonky."
        Rob<br /><a href=\"http://www.robshawk.com\" target=\"_blank\">1994 Firehawk#319</a><br />11.83@120.61<br /><a href=\"http://www.RobsHawk.com/MODLIST.txt\" target=\"_blank\">Slightly Modified</a><br /><a href=\"http://www.RobsHawk.com/Jana/Camaro/\" target=\"_blank\">1996 Blown V6</a><br /><a href=\"http://www.RobsHawk.com/NewTruck/images/100_0011.jpg\" target=\"_blank\">2004 Silverado</a><br /><a href=\"http://www.RobsHawk.com/Trailblazer/TrailblazerSm1.jpg\" target=\"_blank\">2002 Trailblazer</a><br /><a href=\"http://www.SDFB.org\" target=\"_blank\">San Diego F-Bodies</a>
          who sells them? link?
          Past Ride
          Current Ride
            thunder racing i belive
              whatever wires you get you can jsut get soem heat sleeve for them. accel and msd both offer heat sleeves, they are available through summit, jegs, and paw
              unless you have a hotter than stock ignition system, big wires are more for peace of mind than they are for more hp.
              personally i have always been a fan of accel stuff. i have never had any fit or finish problems.
              later
              tim
              NJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
                i used an ohm-meter to test the taylors and some accel 300+ 8.8mm's, at the same setting (20k), the taylors read 1.91, whereas the accels read .60 (i tested the same length each time), so the accel's are .8 mm thinker than the taylors, and seem to have less resistance.
                basically any one of these will work, very little differences. the MSD 8.5's, Accel 300+ 8.8's, and the taylor spiro pros. (id go with the cheapest of the three)
                \'94 Firebird, 3.4 M5.<br />Arctic white w/ red anniversary stripe. ASP underdrive pulley set, Magnaflow 2.5\" stainless catback, CAT, Pacesetters, K&N FIPK2, 1000 watt stereo system capped 1F, Eagle Alloys 16\" 077\'s, 180 Deg. Thermo.
                  mangecore i tested with a .42 a foot how long was the wire u tested??
                  2004 srt4 few goodies<br />13.3 @ 103.4
                    wire debate on a FI board, WTF?
                    :rolleyes:
                      This is 12secv6 signed on as misterjuice.
                      Accel extreme 9000 8mm wires.
                      Spark plug boots have a heat protective boot.
                      And you could add heat sleeves
                      2004 SRT4<br />2006 Mercedes ML350<br />1988 IROC - Supercharged and stuff
                        i tested em at a little over a foot
