how much air will the 3.8l inhale if it's running N/A. also how does boost relate to cfm. basically how much cfm equals 1 psi of boost.. thank you.
question on boost and CFM
According to my calculations the 3.8L the airflow rates of the 3.8L are
50cfm @ 1000rpms
150cfm @ 3000rpms
275cfm @ 5500rpms
These are rough calculations based on a volumetric efficiency of 75%. I don't have the actual VE but 75% should be within +/-10%.
Under 1psi of boost the engine should draw approximately
54cfm @ 1000rpms
161cfm @ 3000rpms
294cfm @ 5500rpms
Hope this helps.
At 6000 revs the 3800 will inhale between 350-400cfm of air. Our engine's VE is roughly 0.8 on average. I am interested in knowing what 1psi of boost would be on top of this though [img]smile.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
