4L60E, how much can it handle - FirebirdV6.com/CamaroV6.com Message Board
  • 4L60E, how much can it handle
    I looked around and never found any info on how much this tranny can take in stock form. i know there is a kit from KDS, but i dont know their site. basically when i add my turbo how much hp can i push out of it before my tranny needs to be built.
    It can handle about 350 ft/lbs of torque. You need to look at your complete drivetrain and consider how much torque it can handle, not hp numbers. Don't forget to consider the rear end.
    180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
      My tranny hates 10 psi........
      Really, really bad. [img]graemlins/stickpoke.gif[/img]
      1996 Camaro, Built Motor(L/C,Cam, Ported), T66 FFF Kit, N20, 36 lb. Inject., FMU, 255 Walbro, 00+ Manifolds, SFC, LCA, Tubular K, Adj. PHR, 17x9.5,x11 Chrome ZR1, Front 35MM/Rear 21 MM Swaybars
        a higher stall converter will kill your transmission faster too. And not changing the fluid, and neutral bomb drops.
        Transgo Shift kit will help somewhat to save the life of your transmission.
          Common misconception right there. Shift kits have not been proven to help or hurt them. They will absolutely destroy your tranny if it is already having problems though.
            Yea david's tranny didn't like da boost [img]graemlins/naughty.gif[/img]
              how much would the rebiuld kit help then, how much is it and what is the website to buy it at. i want to keep it somewhat dependable, i know with FI i am taking a risk but its worth it.
                The KDS "Hoss" kit is rated at 400-450 lbft of torque, I would suggest getting a heavy duty reverse reaction shell and bearing, as well as a hardened input shaft and housing if you are going above that with a 4l60e
                  http://www.transmissioncenter.net/4L60E.htm
                  You will have to ask what they can and can't do.
                  The site is pointed mainly to V8's
                  F-Body's and Y-Bodys.
                  But you can give it a try.
                    http://www.pro-built.net
                    Traction kills transmissions.
                    Doing burnouts (no load on the transmission causes internal part failure)
                    The shift kit thing is debateable....some of them increase fluid transfer among other things.
                    \"Since I started working, every single day has been worse than the day before, so that every day you see me is the worst day of my life\"
                      Burnouts shouldnt kill a transmission unless you are having a failure already in your transmission, look at what a car does on a dyno. And cars seem to last all day on dynos, not much load there.
                        burn outs = no
                        brake torquing - YES!
                        <a href=\"http://albums.photo.epson.com/j/AlbumIndex?u=4187730&a=31095602&f=\" target=\"_blank\"> 2000 Black Firebird Y87 </a> <br />K&N filter, Whisper Cold Air Intake, Cutout Exhaust;<br />3.42 Gears, LSD;<br />160* Powerstat, Removed Silencers, MAF screen removed;<br />Zex hyperformance Spark Plugs, MSD Superconductor Wires, Manual Fan<br />Switch<br />15.08@90.86 2.149 60ft
                          even brake launching wont cause problems unless your transmission is already on thin ice. People do some crazy brake launches at the track with corvettes and f-bodys.
                            Just about every problem iv seen dew to transmissions are the follow
                            Too much power
                            Towing too much wieght
                            But most of the problems i see are from people mistreating their transmissions by slamming the shifter into reverse then drive too quickly, neutral dropping into gear, not changing fluid.
                            Auto is not manual dont treat it like it is.
                              Torque converter can cause a lot of excess heat on the tranny as well. I shredded my PI VIG 3500 converter and my tranny on the way to AIS last year.
                              Tranny rebuild with Hi-Energy components(kevlar/carbon fiber)
                              back on the stock converter right now with no Problems
                              I have run a tranny cooler since I installed the first converter.
                              tranny problems have to do with the way your car is setup and how you treat it everyone will get different results.
                              I believe with my rebuild and hi-energy components mine can handle in excess of 350-400HP to the wheels w/ major traction as in 1.7 or lower 60'. This is going to be spraying a 120 dry shot on a 2800 Yank converter and I'm not the slightest bit worried about my tranny.
