Random FI Question... - FirebirdV6.com/CamaroV6.com Message Board
  • Random FI Question...
    Just curious... would a SC AND turbo work on a 3.8 F body?
    Do you mean like stacking them? Like having the SC feed the turbo. It could be done, would it be practical..no...and would it fit under the hood of an f-body...probably not. Not to mention that tuning for a setup like that would be nearly impossible along with an engine would have to be built to hell and back to handle that amount of pressure but I have seen it done before on large diesel engines where a turbocharger feeds a supercharger.
    1995 Arctic White Camaro. 3.4L/A4<br /><br />\"Stupid men make mistakes, wise men learn from mistakes\"
      I'm sure it could be done. I've heard people are doing it to Cobalt SS's (the supercharged ones, not the sh*tty badged base models...) It doesn't neccesarily mean the engine would have to be built to hell either. You could just use the supercharger set for 6 psi, for off the line power, and then when the turbo spools, only have it set for about 5 psi at 4000 (or whatever) rpm. I'm assuming that means 11 lbs. of boost, which a 3.8 should be able to handle for a little bit.
      Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
        How are you gonna just "turn down" a supercharger at a certain RPM? I believe you can either supercharge or turbo a stock 3.8 to its limit... why would you want both?
        \'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
          you can do it with a roots blower and a turbo.... only problem is the roots blower does not fit in our RWD car.
          ZZP has a twin charged GT running 9's
          www.turbov6camaro.com
          1997 3800 Series II Camaro
