Im going to ask this question here. I have had a bit of a change in heart and will be planning on Tiagos kit next year when I wont have to strain for the money. In the meantime, Im planning on a cam in the next couple of months. Originally I was going to put in the 4x4 Extreme cam and stay NA, but now with turbo in the future, I want to know what your opinions are on the VS cam when used w/ the turbo kit? Other suggestions are appreciated, but I only want to swap cams once, and it has to be something that will run good NA for the next year.
VS cam and boost?
206/216 at .050"
Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
115 Lobe Separation
link to zzp's page on the cam....
http://www.zzperformance.com/zzp/pro...ion_vs_cam.htm\'01 Mineral Grey SVT Cobra<br />-former F-body owner
Or for that matter, how would a
225/230 (or 215/220)
.310/.310
115 lsa
handle boost in your opinion?
I've run these numbers on dyno2k and gotten some very nice theoretical gains n/a, but I don't know anything on the flow numbers on the kit so I can't simulate that.-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
Originally posted by Tiago:
turbos like the higher lsa-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
Tiago, do you have any specs on the flow rates from your kit? For instance, how many cfm the turbo puts out? I'd like to crunch some more numbers tonight to try and find a good mix of numbers for a cam that would work well in both n/a and fi applications since I'm more likely to have the cam I want installed well before I can afford the turbo kit.-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
CAM-901 - INTENSE™ Stage 1X Turbo Cam
duration @ .050": 211º/204º
lobe lifts: .323"/.320"
valve lifts with 1.60:1 rocker arms: .516"/.513" lobe separation angle: 116º
intake centerline: 110º
This is for a stock valve train/heads, it is what I am going with.
Why would that cam have so much more intake than exhaust?
I'm by no means an authority on cams, but I though that since the turbo would be forcing in so much air there is less need for intake and you would be more worried about getting it all out?
Hell I don't know...that just makes sense to me.Shawn<br />2002 Silver W68 Firebird
Hell I don't know...that just makes sense to me.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
