Yeah, I think its pretty much a general concensus that I should go specifically toward a turbo cam rather than a 'one size fits all' approach. I'm holding off on cam/engine mods until after I get Tiagos kit, then following Intense's stage 3 build-up. suspension work now instead of cam.
..... That and my wife picks up a 2002 Monte Carlo SS on Monday to play w/ as well. It'll be the battle of the FWD 3800 vs. RWD 3800!!
Im looking into it... as long as it will bolt onto the L36 w/o a problem. the M112 might be a little much. I dont want to have to tear apart and upgrade an essentially brand new engine. I'm hoping for 5-6 psi from an M90 on the stock 9.5:1 L36.
Originally posted by ellik: Im looking into it... as long as it will bolt onto the L36 w/o a problem. the M112 might be a little much. I dont want to have to tear apart and upgrade an essentially brand new engine. I'm hoping for 5-6 psi from an M90 on the stock 9.5:1 L36.
It's not a direct bolt up, you'd have to get an L67 lower intake, heads, change the crank shaft pulley, fuel injectors= booster pump or intank pump, and reprogram your PCM for the changes to the fueling system
Originally posted by Timbo1969: It's not a direct bolt up, you'd have to get an L67 lower intake, heads, change the crank shaft pulley, fuel injectors= booster pump or intank pump, and reprogram your PCM for the changes to the fueling system
thats exactly the answer Ive been looking for... thank you. Now I can compare that additional cost to the centifugal set-up.
