i know supercharger cams should favor the exhaust side, but i recently put in a 224 224 duration custom comp cam with .5 and .52 inch lift w/ 1.6 roller rockers. Can i supercharge my car with this cam, or not at all. Use a vortech v-1 maybe, or powerdyne bd 11-a?? btw the lsa is 113*
Is my cam ok for supercharging?
A cam won't prevent you from using a blower. Even a turbo/nitrous cam would work fine with the blower, and probably still make more power than stock. The only difference is that you wouldn't make as much power as with a dedicated blower cam.Matt
1998 Mystic Teal Camaro M5
