i need imformation about l67 eternals.. - FirebirdV6.com/CamaroV6.com Message Board
  • i need imformation about l67 eternals..
    i had detonation about my engine..
    its third time... i will be crazy~
    too hard~~~ tuning bird in korea...
    so im thinking about selling my supercharger kit~
    seriously~~ but~~~~
    i think... supercharger success is almost~ done..
    so.. im confusing now~~~~~
    hmm.. and now... i have to rebuild my engine..
    for me.. i have two things...
    1thing is just go with stock iternals.. without
    supercharger~
    the otherthing is go with l67 iternals with supercharger~
    which one should i have to go~?
    if i go with supercharger...
    give me any information about l67...
    where i can buy~
    which one should i have to change?pistons, rings
    rods, thats it?
    and how much is it? ^^:
    what is benefit of it?
    will it be best mod?
    1997 firebird convertable.<br />intense 8.5:1 forged piston,rods,slp1.8 rockerarm<br />255welbro,28injectors,MAF,CIA headers,magnaflow exhaust,intercooled powerdyne S/C,TAXAS racing ECU tuning,coni shock with spring,roll bar,etc~
    crankshaft = same as ours
    connecting rods = powerder metal
    pistons = lower compression 8.5:1
    We can use just about everything below the heads, the L67 upper engine cannot be used with out engines, unless you plan on using the stock blower. You might as well buy a GTP then if you want a roots blower.
    All you need is some forged aluminum pistons.
    custom connecting rods or Series III L67 rods (make sure they are from a Series III)
    You could either have a custom crankshaft made or have the stock one machined for strength.
    your bottom end will take lots of abuse after that.
      I think it's because of poor gasoline that your having detonation. Do you have TRC-1 boost retardant?
      Stephan has done the L67 set up. www.projectvirus.com
      I think it will cost you alot more though. I think you should turn the boost down for a bit to 6psi for now and try to work out the problem from there. To high of a boost and poor gas can damage your engine.
      An intercooler would help you alot.
        L67 Part GM Part Number Price (each) Price (set of six)
        Piston 12539085............$43.35.......($260.10 for all 6)
        Connecting Rod 24502895....$35.40.......($212.40 for all 6)
        Ring Kit 12480825..........$17.85.......($107.10 for all 6)
        Main Bearing 12480819......$14.70.......($88.20 for all 6)
        www.gmpartsdirect.com
        yes L67 would be better b/c it would lower your c/r to help stop the detination
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          thanks.. all post~ you guys are my teachers..^^; hehet~~
          i have learned so much things from here..
          and.. do you know.. why i confused between go with supercharger and not go with supercharger?
          if i go without supercharer~ maybe..
          i will not come here anymore~ ^^
          i read so much~ here and it was geting my habbit~
          and.. now.. i feel like your my friend..^^
          thats why i go with supercharger eventhough
          i am very hard situation go with supercharger
          anyway~ ^^;
          ..i have TRC-1 and seted 7^^;with 9psi boost
          i was in proceeing intercooler almost done...
          so.next mod will be
          entercooler
          with 6psi and.. l67iternals.
          will be ok~ for me..
          dont you think so? ^^;
          hehet~ hmm.. 3 times detonation ... i will be cazy......
          hmm...
          and.. how about tune ECU?
          dont i need? tune ECU?
          [ May 15, 2004, 03:16 AM: Message edited by: woojong ]
            yes the intercooler and 6psi will do fine with th L67
            L67 make c/r 8.5:1 stock 9.4:1
            good for detination.
            yes ECU tunning will help you out alot too [img]smile.gif[/img]
            what year car?
              97 firebird convertable~ hmm.. in korea..
              how do you think~ i send ECU to america~
              and tune it and back~
              hmm.. will it be worth for me?
              and if i do.. how much should i pay~ ^^;
              and.. i have to get l67 itenals very very quickly~
              but im not sure..now im searching gmparts.com..
                type in those parts number and you should not have aany trouble finding them
                umm if you got the cash you could get HP tuners software for the 1997 when is comes out (like month or so)
                www.hptuners.com
                  thanks.. viper...^^ i likes viper too~~~~hehet~~~
                  i will have this car~ for long..long time..^^
                  already 7years past~~ ^^
                  hehet~
                    Lower compression will help lower the temp. of your car. If your going to go for l67 you can set your boost to 9psi and still be safe. With an intercooler you can go to 12psi without any problem.
                      yup~ i think..so mighty thor~
                      but...i have problem..
                      hmm.GMpartsdirect.com.. doesnt have
                      abroad shipping service..but im in hurry.. :(
                      i want to get all parts of l67 directly
                      from america to kroea...
                      dont you have more faster site? for getting
                      l67 parts..? which has abroad shipping service..
                      and... is l67's pistone same as metal with l36 one?
                      or semy forged?
                        L67 is stronger then L36
                        do you have any gm dealer over there?????? any gm place should be able to get them
                          http://www.trademotion.com/partlocat...?siteid=213761
                            yes the place above does ship to korea but
                            its $896.58 PLUS shipping
                            there a little higher on prices but they can get them to you [img]smile.gif[/img]
                            see if this link works
                            https://www.trademotion.com/memberservices/index.cfm?action=cart_login&redirect=https%3A%2F%2 Fwww%2Etrademotion%2Ecom%2Fshoppingcart%2Findex%2E cfm%3Faction%3Dcheckout%26siteid%3D21 3761&siteid=213761
                              i you wantde forged thats gogin to bee $$$$$ about $800 for pistons and 250 for L32 (2004) rods
                              www.intense-racing.com i don't know about the shipping tho
                              [ May 16, 2004, 03:36 AM: Message edited by: viper04af ]
