mmk, cant decide on turbo set up or blown set up - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Originally posted by ssms5411:
    I know, this happened Sunday night coming home from work. I like opening her up on the highway every now & then.
    yup thats how it happens... pulllllllllllll POW
    jsut dyno in 4th i did with broken 3rd and 5th gear lol
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    • #17
      Did you ever look into G force transmissoins before you put in your A4?
      • #18
        yeah then i dynoed they are rated for 600 HP(crank) or 500 TQ
        so with 3 psi more i would be pushing it to it limits
        you can send Gforce yours for about 2K and they biuld it and send it back
        • #19
          Nice, I don't think my PD is going to put out that much Hp.(LOL) I just don't want to break another gear. Your A4 , is it going to hold that much power? Or did you have to have it built up?
          • #20
            www.rosslertrans.com
            got the stage II biuld for the 4l60E ;) should hold 9's
            • #21
              If I get between 330hp and 350hp , I'll be happy.
              • #22
                I see why you went with the A4 now.
                • #23
                  plus A4 will let my 10bolt last longer...
                  and the turbo like's the A4 A LOT BETTER
                  • #24
                    Too bad they don't do T5's like that.
                    • #25
                      http://www.fordmuscle.com/archives/2...uild/index.php
                      • #26
                        http://www.g-forcetransmissions.com/tran_gt-5.asp
                        price
                        http://www.g-forcetransmissions.com/tran_t-5_price.asp
                        • #27
                          do i need to get any other mods with my PD to set it up correctly? Or just buy the kit and go? Thanks alot for all the help guys :D
                          • #28
                            fuel psi guage, and boost/vac and Wide Band O2 sensors is one the best things you can get that way you can street tune... and dial in the car... since you have HP Tuners you can ditch the FMU and get biger injectors...
                            this also make it "safer" becuase you know what the car is doing.
                            upgrade your exhuast.
                            rear if you have a open Diffy.
                            • #29
                              I already got my diff and exhaust upgraded, I dont have hp tuners though. I was just gonna do the tsp tune again and tell em I got a PD at 6 psi. The Gauges seems like the only thing I really need and wideband 02 sensor ;D.
                              • #30
                                deff get hp Tuners
                                add your and mods into your sig so we know whats going on
