Would it work ok?
GT2 Cam + Supercharger?
what the cam specs ?www.turbov6camaro.com
1997 3800 Series II Camaro
cams arent my strong point but i would think you would want a cam that makes more power down low so your powerband isnt so one sided.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Lotta overlap with the GT2 cam. Would make more power with a cam that has less overlap (wider LSA).Matt
1998 Mystic Teal Camaro M5
Originally posted by 97 30th RS:
216°/216° at .050"
Intake Lift .317" (.507" lift at 1.6:1 rocker ratio)
Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
111 Lobe Separation
GT-2 cam
yes it will work , but you won't get 100% out of the combo
[ October 29, 2004, 03:58 PM: Message edited by: viper04af ]www.turbov6camaro.com
210°/210° at .050"
113 Lobe Separation
How's that? Thats the GT cam. I'm looking for something that would perform well both NA, and with FI. I plan on getting the cam before spring (when I plan on picking up the SC), so I'm looking for a good candidate.94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
Originally posted by tWiStEdBird:
210°/210° at .050"
113 Lobe Separation
How's that? Thats the GT cam. I'm looking for something that would perform well both NA, and with FI. I plan on getting the cam before spring (when I plan on picking up the SC), so I'm looking for a good candidate.www.turbov6camaro.com
Uh, I copied the specs from ZZ perf. Trusy me those are GT-2 specs. The only differences are the lobe separation and the duration. I would use the Gt cam for a little bit better low end , and you would still have nice power up top.97 Camaro RS<br /><br />\"Just a V6 huh?, let\'s go find out how slow it is\"
i woulda LOVED to do a cam and valve job when i had my block done but that woulda been like 1 - 2 grand more than i spent...which already left me maxed out hehe [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Uh, I copied the specs from ZZ perf. Trusy me those are GT-2 specs. The only differences are the lobe separation and the duration. I would use the Gt cam for a little bit better low end , and you would still have nice power up top.Matt
You still don't have a lot of overlap, even with that tight 111 LS on the GT2.
I have basically the same cam, and at .05 lift the exhaust valve closes 8 degrees before TDC whereas the intake valve opens right at TDC. There's no overlap at .05" which indicates not much if any a .04999"-.000001"1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
i'd say go ahead and buy a blower cam since that is the final combination. It will still run good NA but run even better w/the blower. Something like the Comp 210/220, .512/.512 on a 115LS.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
