I assume it has something to do with the materials made, cfm, displacement, etc. I would like to know if there are any formulas for a project I am doing. Please don't respond with "trial and error", I can't afford to buy two engines. [img]tongue.gif[/img]
So how do you determine how much boost an engine can handle?
All engines have millions of tiny flaws, and each engine is completly different. Some 3.8's will hold 600hp stock. Some will die at the 200hp level. Only way to find out for sure is to break it.
As a general rule with 3.8s anything over 9psi creates lots of blowby. 6psi is fairly safe though.
You can get away with more boost if you run an intercooler, and/or higher octane fuel.Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
Well in that case pick up Corky Bells book, it has some really good sections on increased engine wear, as well as some tables that relate Compression ratio to maximum boost pressure and octane of your fuel.Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
If it makes you feel better I plan on running 10-15+psi of boost on a T70 turbo which will put my little 3.4L some were in the 400+HP rangeBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
when you brake it down it all come down to chamber PSI. to high and one of these things will happen
you'll lift the head off the block, blow out a gasket, crack your pistons and/or shatter rods/crack, or have some vavle flow and show vavle through the head lolwww.turbov6camaro.com
1997 3800 Series II Camaro
Book store, it's a pretty common book for just about any decent sized book store to carry. Amazon and other online bookstores have it tooAIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
depends on a lot of stuff. Most important, compression ratio and fuel octane. too much compression or too little octane and you'll get detonation. other things such as cam(design, specs, ect.), heads(ported/polished, thermal coated, cryo-treated), pistons(forged, cryo-treated, thermal coated), crank/rods(cryo-treated, balanced, shot-peened), spark plus(gapping, heat-range), intake manifolds(ported/polished, gasket matched), exhaust manifolds(port matched, low-restriction), as well as other little things will affect the amount of boost you can run. usually, a motor with a better flowing top-end can hndle more boost, lower compression and higher octane can handle more boost, and cryo-treated parts can handle more boost.2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
its not they canhadle more the can take more abuse
long as you don't KR thats the big killer and high temps from heat soke hurts too and cause's KR
you can only fit so much air into so much space, sometime something is going to give lol
RPM is a big factor too
if engine speed is increased 3 fold, the internal load is 9 times as great!www.turbov6camaro.com
Thank you for the replies. I should've picked up "Maximum Boost" and read it before I posted [img]graemlins/stickpoke.gif[/img] but I will be getting it in a few weeks.
Oh, and for the confused people who don't read, this is not for an L32 or an L36 engine :mad: [img]tongue.gif[/img]2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
Oh, and for the confused people who don't read, this is not for an L32 or an L36 engine :mad: [img]tongue.gif[/img]www.turbov6camaro.com
Originally posted by viper04af:
</font><blockquote>quote:</font><hr />Originally posted by WishIHad$$$:
Oh, and for the confused people who don't read, this is not for an L32 or an L36 engine :mad: [img]tongue.gif[/img]Originally posted by Mighty Thor:
A non-intercooled has done well at 9psi. but above that, it gets dangerous.
With the intercooled one you could go 10-12 and still be OK.
Anything above that on a stock engine, you're pushing it.2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
