:D I am installing my powerdyne kit this weekend do you guys have any tips or suggestions.
powerdyne install
1. Upgrade to the John_D wrap... [img]smile.gif[/img]
2. That little cross brace goes to a bolt underneath the heater hose.
3. Grin real big the first time you get on it!\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
if this has not been covered for you in earlier post(s)...correct me if I am wrong guys...
Gap plugs to .035
Fill up with premium fuel
Do a search here on throttle body PVC block / PVC valve cover breather. (there seems to be two main ways to do this.) I am going with a threaded plug in the throttle body and a $12 valve cover pvc breather cap rather than the 'drill holes in throttle body method.'
the John_D wrap uses a 103" belt. (for 9psi pulley.) Gatorback part number is 4061030
He thinks you may need a slightly longer belt for use with a 6 psi pulley. I have researched this for dayco and gatorback...they show part numbers for 103 3/4" belts...but they are not in production/not available ANYWHERE. Net step is the 105 which you already have with your kit.
I am pretty sure I have read here that the 103 belt works...but the fit is a PITA...but real tight when on...no adjustment needed.
Good luck. Let us know how it goes. I am very interested in this topic.
