I know that boost on an l32 isnt recommended without mods but the 2004 Grand Prix supercharged has an L32.... Whats the difference between that L32 and my l32?????
Is the compression the same? What boost do those run?
Mystic Teal Metallic
Originally posted by teal99camaro: ok i get it now.. I got my Ls mixed up but i still might be getting that supercharger........
Anythign i should do before i install it if i get it?
Yeah, you will need L67 heads, lower intake manifold, harmonic balancer, fuel rail/injectors and tuning software. I'm not an fbody person, but from what I hear, it will not clear your hood.
I think it would be a great project if you decide to do it. Good luck.
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Go for it... I looked into it a long time ago but couldn't get any prices from the guy that would be importing it over for me. I wasn't too hardcore interested just half assed looking.
if anything is needed for clearance just get a small cowl hood. [img]smile.gif[/img] Otherwise it will fit underneath the cowl. Be sure you get the lower intake manifold that matches the blower as I believe it is shorter than the stock NA 3.8 piece which will allow for it to fit..
Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
it will come with the intake manifold... i have a 99 so i dont think there will be issues...and i think i'll clear just fine, if nto SS hood biznatches
I dont think it would be hard to do at all with the holden supercharger, I was just giving a list of parts that you will need and a possible need for a cowl hood. I think it could be done rather cheap and would give great gains for the money. I think if you get hp tuners and change all the timing and fuel tables over to stock GTP tables, it would run fine with the higher compression. [img]smile.gif[/img]
Would it come with a throttle body that bolts to that supercharger? That could be a minor setback making an adapter plate to mount our throttle body/MAF to that supercharger.
