Has anyone ever heard of the PWR Air-liquid intercooler. it looks a lot different than normal intercoolers but also easier to mount in our limited space. if they are only medium grade could you run through more than one in say a y configuration and come back together. it just looks really easy to mount.
Air to water intercooler
2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhardTags: None
Those things are expensive.AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
this is a pic of the intercooler on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2436426242
is this a good price for a air to water intercooler?2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
its only 360 dollars for a 4" diameter 6"long one.
that seems cheap for an air to water.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
i knew i needed the pump and lines but was unaware of needing a second radiator. why would i need that as well? while im asking, how much better does the air to water cool the air than an air to air ic.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Air-water is used where there is NO or virtually no space for fresh, cool air to be hitting the I/C. THe I/C is mounted where convienent, and then a fresh supply of radiated (or, for some folks, through a cooler with ice) water is used to cool the intake charge.
In the case of the f-body, there is a fair amount of space in all of the 4th gens for mounting an air-air intercooler, it just must be chosen with the proper dimensions, etc.
If you haven't yet, pick up a copy of Maximum Boost by Corky Bell.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
has anyone heard of a water cooler to cool the water running through the ic.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
thanks for the suggestion on the book. cant i use the air from the fans in behind the radiator to get airflow ofer the ic.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
<blockquote>quote:</font><hr>Originally posted by Wicked 3800 V6:
-Rob<hr></blockquote>
dont take everything that he has to say as if it is written in stone. most of the stuff he works with is for road racing, he is not a fan of air to water IC's or water/alchol injection, but if you read other books by other authors they praise water/alchol injection..-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
True, it depends on what you are into. A icebox will give you cold water for a 15 second run, a good-flow water setup will give you warm water for your laps ...
But, we can fit air-air on our cars, so why not?
Unless you're really going for the ice effect, then you could do a serious icebox setup.
ok so from what i understand the water cooling is more for track use and air to air is more road friendly. is that the case? i originally thought that there were other ways to cool the water than just ice or a radiator. if there is no other way then i guess ill go air to air. i have a ram air hood so if i remove my airbox assembly would it be prudent to place the intercooler there (for air to air) and use a cone filter donw low close to the road? oh year and what would be a good size intercooler to use with a v1-s trim vortech running at about 10psi, i was thinking around 24x12x3 for air to air.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...16 hours ago
