did u guys use braided oil lines? also my real question was how did u run the oil lines? also are any of ur cars turbo timed??
oil lines,and turbo timing...
You don't need a timer, just let it idle before you shut it down if you've been under boost.
For oil lines I used some blue stuff ... some folks plumb with braided, some with brake line and banjos, some with dinky rubber. Make a wise choice.
I seem to be the only one of us running a restrictor ...
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
For the oil feed I Tee'd off the oil sender sensor and for the return i tapped into my oil pan....used steel braided lines.Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015
<blockquote>quote:</font><hr>You don't need a timer, just let it idle before you shut it down if you've been under boost.<hr></blockquote>
How long though?
-Justin<b><a href=\"http://www.cardomain.com/id/drkmind11\" target=\"_blank\">2000 Red Firebird Coupe, A4.</a></b> ((3.42 Gears, LSD Stock))<br />Details: 3\" Edelbrock Exhaust, 3\" Catco Cat,160* Thermostat, 8% Tint, TA Chrome Wheels, Viper 550.
is anyone here plannin on doing rebuild and big boostin?? cuz i plan on doing the preparation for the rebuild along with the turbo installation in the stock car. By this is mean, heavy duty fuel sys (including big injectors), and working with the ECU. My bro's turbo DSM's ECU is controlled by his handheld pc. He can see everything goin on with long term and short term fuel pressures and oil pressures etc, boost graphs while doing a run. Does anyone plan on doing this?
if i were you guys i owuld jsut get a turbo timer from us. we sell hks ish and there is a harness for it too plug right into the stock computer. they range from 120 and up for the timers, and the harnesses are around 40 bucks additional. not a bad deal for a ftick lookin computer and piece of mindboost, you got it???
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 hours ago
