Yeah, so i have seen the gas milage of 3.4Ls on turbos, but what about 3.8L? Right now i drive my car pretty easy, unless i am racing, i shift ever gear at 2,500 or lower, especially when i get to 4th. Anyways i get 20-21 mpg all streets, and no freeway. Once i throw Tiagos kit on what should i exspect to get, asuming that i drive the same? And what would the procharger kit net me?
3.8L FI gas milage
a few links down the exact same topic was posted.
its under the name "Fuel milage while boosted?". . basically though mileage wont change much until your car comes under boost but the turbo will definately get better mileage. i have only heard good things about that kit on this board. also try checking under the turbo kit questions link also on this page they may have more on the mileage in there. another thing to try (and i dont mean to be a prick) is to do a search. the search on this page works very well. i hope this helps
[img]graemlins/fluffy.gif[/img]2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Search. Shouldn't change much unless you're hitting the boost ... so you'll probably average a little lower, but cruising on the highway should be no different.
I opened up my exhaust a bunch, so I expect it to go up some.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
as everyone has verified, gas mileage wont change until under boost.
for example, and for comparison:
the buick grand national still gets like 22mpg on the highway, and can cruise at 100mph without the turbo spooling. but get it into boost range, and your gas is affected.
Yeah, i know about the turbo, but what about supercharged?2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
still little to no change unless under boost2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...19 hours ago
