Boost question - FirebirdV6.com/CamaroV6.com Message Board
Boost question
  • Boost question
    Is it possible to see 30psi on a 2002 V6 Camaro? I know the engine is tough (the story about the LS1 guy who tried to blow up his 3800 was funny.. he failed at blowing it up). I have a dream of breaking into the 9's with a V6.
    One idea is with a procharger F1A.
    The other is turbo(s).
    The only other issue I can see with that much boost is fuel supply. no one makes aftermarket injectors for 2002 V6 Camaro's. Looked at accel and some other company and they don't fit/work properly.
    **30psi is assuming that everything is built ie. internals balanced and blueprinted, valvetrain, transmission, seals ect.
    What is the max boost someone has run on their v6?
    I understand that this sounds to be crazy, but ever since I saw shane's supra... I wanna build a v6 to beat it.
    \" Eat Rice With Pushrods \"<br /><br />My Car and What I Did <a href=\"http://www.cardomain.com/ride/2127313/1\" target=\"_blank\">http://www.cardomain.com/ride/2127313/1</a>
    Re: Boost question
    maybe you don't know but the Grandams and GTP's use the same block as our car
    www.intense-racing.com has a GTP ( ithink) running 9.6's
    and
    www.zzperformance.com has 2 cars one running 9.9's and one running 9.8's
    these cars are all FWD also
    ZZP makes an adapter for your injectors to plug in....
    And non of those are close to 30 psi.... i think the most is 25 psi last i knew
    remember its not PSI that counts its CFM,
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      Re: Boost question
      Yeah that's true. The fastest LS1 used a Procharger. I don't remember but it didn't look like a lot of boost but the CFM is way up there.
      The used to be fastest LT1 used a Vortech and broke into the 8's with only 18psi. CFM was up there too.
        Re: Boost question
        Is anyone flowing 320-330cfm? I know some LSx guys are pulling those numbers. Can i pull those numbers with a v6? So technically I can bolt a gtp intake with a ported m90 onto my block? I didn'k know about those 9s.
        Has anyone released any editing software for the 3800? I'd like to plug the laptop up to my obdII port and monitor my car(more for learning purposes and tuning)
          Re: Boost question
          you cant just "bolt up a l67 intake and m90. its alot more complicated than that and takes some fabricating and $$$$. the m90 wont have clearance under the cowl without modification,l67 heads are different(think injectors here)
          youre better off building a turbo kit IMHO.
          Follow me!
          Or this
            Re: Boost question
            and yes there is tuning software available. Hp tuners and Dhp powertuner
            Follow me!
            Or this
              Re: Boost question
              Just had to make sure i wasn't crazy for thinking they wouldn't work. At a local meet down here i had some people telling me that all 3800 parts are "interchangeable." i thought the bolt pattern was different and thegaskets, and the TB(angled I thought). Hp tuners has software that I can place on my computer to monitor my engine and such?
                Re: Boost question
                that parts are inter changeable but the dont fit under our hoods you sould have to cut alot of stuff to make it for a mir 60HP at the crank,
                there's 2 turbo kits for sale right now one is 1800 and one is 2300, would would cost at least that it make the M90 work if not more.
                yes HP works for you car lond as its 1997+ years
                  Re: Boost question
                  Who's got a turbo kit for 1800 or 2300? I really appreciate the help.
                  Viper, what kind of software were you using to monitor your engine. It looked like something I was looking for. I read your tuning webpage, can't thank you enough for making that.
                  I can run about 9psi of boost on stock internals right? It's going to take me a few months to pull money together for abbott headds and blower cam.
                  Does anyone make metal gaskets for our cars?
                    Re: Boost question
                    Check these links out. They are a day or so old, but as far as I know they are still for sale. Killer prices too! They will work great for you too since you have an 02. I would have bought one of them, but too much fabricating to my 97. :(
                    http://forum.camarov6.com/showthread.php?t=64752
                    http://forum.camarov6.com/showthread.php?t=64617
                    I have no idea about the gaskets.
                    Good luck with the project, keep us posted on results.
                    1997 Camaro RS A4
                    2006 Chevy Colorado
                    2003 Kawasaki Ninja ZX6-R
                      Re: Boost question
                      i use HP Tuners with the upgraded calbe and a Wide BAnd O2 to tune.....
                      9PSi will be fine long as you upgrade your fuel pump and injectors or use a FMU (if you get the tuner just upgrade the injectors)
                      ether one of those kits above will work great for you :)
                        Re: Boost question
                        Thanks for the info quys. If i were to upgrade the injectors and do the walbro intank pump, would I be fine at 12psi? It seems like I'm going for boost numbers, but Im going for a mild performance out of my car. I'd like to atleast run with a stock trans am. Later on next year I'll be selling my car and getting a z06.
                          Re: Boost question
                          that will work perfect with 12 psi
                          • Manimal
                            Coil springs
                            by Manimal
                          • Manimal
                            Newby here
                            by Manimal
