I should have my Supercharger here tommorow morning, and my pulley should be here by thursday as well as my new HID kit, Innovative Wideband, ASP 2.85" Grooved 8 Rib Pulley, KB Boost-A-Pump, Intercepotor OBDII Scanner(To moniter KR, and other things like Injector Pulse Width ect... I cant wait. 9PSI & 125 Wet Shot :-)
11's or busted motor(which means LS1 Swap)
[ full bolt on\'s and blown.]<br />[formerly known as naptown]<br />[just know that im teh man ]
